Temperature Sensor
What are the programming for temperature sensor that will detect temperature and display current temperature in LCD and also android?
(deleted)
I will gladly write this program for you for £2500 + VAT
What a rip-off. That code shouldn't cost more that £2499 to develop. :)
FaiZamri: What are the programming for temperature sensor that will detect temperature and display current temperature in LCD and also android?
I think you have the wrong idea about this forum. It is here to help you not do things for you.
@FalZamri, is this an idea that you wish to build yourself, or do you want to find someone who will build it for you?
If you wish to build it yourself you will need to learn how to use the Arduino system. The project is quite feasible, though not trivial. I suggest you get yourself an Arduino Uno, download the Arduino IDE and then learn from the many examples that come with it.
You might also like to look up the details of an LM335 temperature sensor. I have never used LCDs so can’t give you any advice on that.
…R
Look here for inspiration:
