Hello!
I'm trying to make an art installation but I don't have a lot of experience with arduino. I'm trying to convert temperature to tone. So, for example, when it's 23 degrees you can hear a C note, and when it's 26 degrees you can hear an E note, and so forth.
I found the pitches.h library, which works perfect for what I want. And I found this code:
const int hot = 87; //set hot parameter
const int cold = 75; //set cold parameter
pinMode(A2, INPUT); //sensor
pinMode(2, OUTPUT); //blue
pinMode(3, OUTPUT); //green
pinMode(4, OUTPUT); //red
int sensor = analogRead(A2);
float voltage = (sensor / 1024.0) * 5.0;
float tempC = (voltage - .5) * 100;
float tempF = (tempC * 1.8) + 32;
Serial.print("temp: ");
Serial.print(tempF);
if (tempF < cold) { //cold
digitalWrite(2, HIGH);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
Serial.println(" It's Cold.");
else if (tempF >= hot) { //hot
digitalWrite(2, LOW);
digitalWrite(4, HIGH);
Serial.println(" It's Hot.");
else { //fine
digitalWrite(3, HIGH);
Serial.println(" It's Fine.");
delay(10);
Which is used to read temperature with LEDs. But I don't really understand how I can replace this with the notes from the pitches.h library. So instead of the lights turning on, you hear sound.
The arduino is connected to a speaker and a temperature sensor. I've got the temperature sensor to work and the tones to work on the speaker, but I don't get them to work together. Does anyone know how I can do this?
Thank you very much!
