Temperature Web Panel and DHT22 sensor
Hi everyone, I'm really a newbie and I was try to get the temperature web panel example work with a dth22 sensor. There is someone able to teach me how? TIA
I suggest you to start with youtube, there's a lot of guides that show you how to make things work ;)
I find out that ... if I'm using any Serial or Console print(), println() or write() statements in setup(), they won't show up when you open the serial monitor or Console connection
so every tutorial use this ... and i'm stuck
I would suggest to start from something easier, like for example 04.Communication > ASCIITable
Thanks Federico... but in the meanwhile I'm learning I just would like to know if there is a Class for DHT11, DHT22 working for arduino Yun and maybe use someone's else code to grab my data...
Google brought me here http://www.adafruit.com/products/385#Learn
Finally works, that’s my code
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include <Console.h>
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
  Bridge.begin();
  Console.begin();
  while (!Console){
    ; // wait for Console port to connect.
  Console.println("You're connected to the Console!!!!");
  Console.println("DHTxx test!");
  dht.begin();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Console.println("Failed to read from DHT");
    Console.print("Humidity: ");
    Console.print(h);
    Console.print(" %\t");
    Console.print("Temperature: ");
    Console.print(t);
    Console.println(" *C");
    delay(5000); // Poll every 50ms
Most of the example the work with serial.print so in order to fix it I managed with console print!!!
Thank’s Federico for your help
nice job, well done ! :)
Però la pappa pronta non me l'hai passata :P
