Template class problem
Using my template array in two ways:
  1. With a class CElementDetails object, with a copy constructor.
  2. With a simple int data type
Calling the CArray::add(...) function with my object (class CElementDetails) hangs the sketch up.
Calling the CArray::add(...) function with a simple integer does not hang the sketch up.
What am I missing here with template classes and objects.?
CArray<CElementDetails, 20> m_arrayElementDetails;
CElementDetails E;
m_arrayElementDetails.add(E);
// This hangs up my sketch
And
CArray<int, 20> m_arrayElementDetails;
m_arrayElementDetails.add(10);
// This does nit hang up my sketch
Source file: array.h
template <typename DataType, const uint16_t nMaxSize>
class CArray
  public:
    //Construction, destruction & initialisation
    CArray();
    ~CArray();
    bool enqueue(DataType DataVal);
    bool dequeue(DataType &DataVal);
    bool push(DataType DataVal);
    bool pop(DataType &DataVal);
    void fill(DataType DataVal, const uint16_t nSize = 0);
    bool add(DataType DataVal);
    bool insertAt(const uint16_t nI, DataType DataVal);
    bool removeAt(const uint16_t nI, DataType &DataVal);
    inline bool setAt(const uint16_t nI, DataType DataVal);
    inline bool getAt(const uint16_t nI, DataType &DataVal);
    DataType operator [](const uint16_t nI);
    inline uint16_t size();
	  uint16_t capacity();
    inline bool isEmpty();
    void empty();
    bool find(DataType DataVal);
  protected:
    // Data
    DataType m_arrayData[nMaxSize];
    uint16_t m_nCurrSize;
CArray<DataType, nMaxSize>::CArray()
  memset(m_arrayData, 0, nMaxSize * sizeof(DataType));
  m_nCurrSize = 0;
CArray<DataType, nMaxSize>::~CArray()
uint16_t CArray<DataType, nMaxSize>::size()
  return m_nCurrSize;
uint16_t CArray<DataType, nMaxSize>::capacity()
	return nMaxSize;
bool CArray<DataType, nMaxSize>::isEmpty()
  return m_nCurrSize == 0;
void CArray<DataType, nMaxSize>::empty()
  m_nCurrSize = 0;
bool CArray<DataType, nMaxSize>::find(DataType DataVal)
  bool bResult = false;
  for (uint16_t nI = 0; nI < m_nCurrSize; nI++)
    if (m_arrayData[nI] == DataVal)
      bResult = true;
  return bResult;
bool CArray<DataType, nMaxSize>::enqueue(DataType DataVal)
  return add(DataVal);
bool CArray<DataType, nMaxSize>::dequeue(DataType &DataVal)
  return removeAt(m_nCurrSize - 1, DataVal);
bool CArray<DataType, nMaxSize>::push(DataType DataVal)
  return insertAt(0, DataVal);
bool CArray<DataType, nMaxSize>::pop(DataType &DataVal)
  return removeAt(0, DataVal);
void CArray<DataType, nMaxSize>::fill(DataType DataVal, const uint16_t nSize)
  if (nSize > 0)
    m_nCurrSize = nSize;
    m_nCurrSize = nMaxSize;
   memset(m_arrayData, 0, nMaxSize);
bool CArray<DataType, nMaxSize>::add(DataType DataVal)
  if (m_nCurrSize < nMaxSize)
    m_arrayData[m_nCurrSize++] = DataVal;
    bResult = true;
  return bResult;
bool CArray<DataType, nMaxSize>::insertAt(const uint16_t nI, DataType DataVal)
  if ((nI < m_nCurrSize) && ((m_nCurrSize + 1) == nMaxSize))
    for (uint16_t nJ = m_nCurrSize; nJ > nI; nJ--)
      m_arrayData[nJ] = m_arrayData[nJ - 1];
    m_arrayData[nI] = DataVal;
    m_nCurrSize++;
    bResult = true;
  return bResult;
bool CArray<DataType, nMaxSize>::removeAt(const uint16_t nI, DataType &DataVal)
  if (nI < m_nCurrSize)
    DataVal = m_arrayData[nI];
    for (uint16_t nJ = nI; nJ < (m_nCurrSize - 1); nJ++)
      m_arrayData[nJ] = m_arrayData[nJ + 1];
    m_nCurrSize--;
    bResult = true;
  return bResult;
bool CArray<DataType, nMaxSize>::setAt(const uint16_t nI, DataType DataVal)
    bResult = true;
  return bResult;
bool CArray<DataType, nMaxSize>::getAt(const uint16_t nI, DataType &DataVal)
    bResult = true;
  return bResult;
DataType CArray<DataType, nMaxSize>::operator [](const uint16_t nI)
    return m_arrayData[nI];
    assert(false);
Source file: displayelements.h
class CDisplayElements
  public:
    CDisplayElements();
    virtual ~CDisplayElements();
    bool begin();
    void dump();
    void doGetNextDisplayElement(CElementDetails &ElementDetails);
  protected:
    const char *m_strDelim;
    uint8_t m_nElementIndex;
    // Helpers
    bool readFile();
    bool readTextElement(CString &strFileLine, CElementDetails &ElementDetails);
CElementDetails::CElementDetails(): m_strText(m_buffText)
    m_nColor = m_nTimeMillis = 0;
    m_nPasses = 1;
    m_nAnimation = 0;
    m_bFlash = false;
CElementDetails::CElementDetails(CElementDetails &ElementDetails): m_strText(m_buffText)
  (*this) = ElementDetails;
CElementDetails::~CElementDetails()
CElementDetails& CElementDetails::operator =(CElementDetails &ElementDetails)
  m_strText = ElementDetails.m_strText.c_str();
  m_nColor = ElementDetails.m_nColor;
  m_nTimeMillis = ElementDetails.m_nTimeMillis;
  m_nAnimation = ElementDetails.m_nAnimation;
  m_bFlash = ElementDetails.m_bFlash;
  m_nPasses = ElementDetails.m_nPasses;
  return *this;
void CElementDetails::dump()
  LOG(F("============================="));
  DUMP_VAR(m_strText);
  DUMP_VAR(m_nColor);
  DUMP_VAR(m_nTimeMillis);
  DUMP_VAR(m_nAnimation);
  DUMP_VAR(m_bFlash);
  DUMP_VAR(m_nPasses);
I'm, not sure, this is just a guess. When calling add (CElementDetails) there are some instances created and some destructed. I would suggest adding debug messages in CElementDetails constructors and destructor to see what is really going on. Taking a brief look at your code:
bool CArray<DataType, nMaxSize>::add(DataType DataVal) <- A instance constucted as a parameter to call add function
    m_arrayData[m_nCurrSize++] = DataVal; <- B instance constructed as a copy of parameter instance
    bResult = true;
  return bResult; <- A parameter instance destructed
<- no B CElementDetails destructor called here, but the memory gets removed ???
By the way, is there a reason you are not using std::vector instead?
No, it doesn't. The code you posted doesn't even compile. The datatype CElementDetails is not defined.
