Temporarily disable Serial.event
Is there a way to temporarily disable serial.event? I use serial.event to automatically read the serial buffer to a an array. However, there are some instances that I want to disable this and use serial.readbytes instead.
No. If you create the properly named function, it will be called right after loop, every time loop ends.
The method is not called whenever there is serial data. It is called when loop ends AND there is serial data.
So, rename the method, so it is not called automatically, and call it, or not, at the end of loop(). That way, you can enable/disable the call as you see fit.
ambokyo:
Why ?
PaulS:
Thanks this made it clear.
