Hey I am sitting here on a code and dont know how to go on. I would like to save the value millis () is having when you start pushing the button in an variable as long as the butten is pushed without changing the value. Is there a trick or someting to do that? Or an other way to write the programm Iam programming? In the end my programm should light up an other LED every 10 seconds when the button is pushed without using an delay.
Thank You for you`re help.
const int intervall = 10000;
int schalter = 0;
unsigned long previousTime = 0;
pinMode(2,OUTPUT); //1
pinMode(3,OUTPUT); //2
pinMode(4,OUTPUT); //3
pinMode(5,OUTPUT); //4
pinMode(6,OUTPUT); //5
pinMode(7,OUTPUT);//warn
pinMode(8,OUTPUT); //Warn
pinMode(10,INPUT); //Schalter
pinMode(11,OUTPUT); //Grün
pinMode(12,OUTPUT); //Blau
pinMode(13,OUTPUT); //Rot
schalter = digitalRead(10);
unsigned long zeit = millis();
if (schalter == HIGH){
unsigned long currentTime = zeit;
Serial.println("Timer Ein");
Serial.print("Zeit Vergangen: ");
Serial.println(previousTime);
digitalWrite(11,HIGH);
digitalWrite(12,LOW);
if (currentTime - previousTime == intervall){
digitalWrite(2,HIGH);
if (currentTime - previousTime == 2 * intervall){
digitalWrite(3,HIGH);
if (currentTime - previousTime == 3 * intervall){
digitalWrite(4,HIGH);
if (currentTime - previousTime == 4 * intervall){
digitalWrite(5,HIGH);
if (currentTime - previousTime == 5* intervall){
digitalWrite(6,HIGH);
else if (schalter == LOW) {
digitalWrite(11,LOW);
digitalWrite(12,HIGH);
Serial.println("Timer Aus");
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
digitalWrite(5,LOW);
digitalWrite(6,LOW);
const int intervall = 10000; //Variablen für die ZeitIntervalle wenn immer eine LED leuchten soll
const int intervallb = 20000;
const int intervallc = 30000;
const long intervalld = 40000;
const long intervalle = 50000;
const long intervallf = 60000; //Zeit bis zum Alarm also Timer Zeit
int schalter = 0; // Variable für den Schalter
bool istGesetzt = false; // Variablen dafür das miilis() richtig ausgelesen wird
unsigned long previousMillis = 0;
schalter = digitalRead(10); // Das der Schalter ausgelesen wird
if (schalter == HIGH){ // Wenn eingeschaltet
unsigned long currentMillis = millis(); //Sagt das mit millis()die Zeit genommen werden soll
Serial.println(currentMillis - previousMillis);
digitalWrite(13,LOW);
if (currentMillis - previousMillis >intervall){ // Sorgt dafür das jeweils nach jedem Intervall eine weitere LED angeht
if (currentMillis - previousMillis > intervallb){
if (currentMillis - previousMillis > intervallc){
if (currentMillis - previousMillis > intervalld){
if (currentMillis - previousMillis > intervalle){
if (currentMillis - previousMillis > intervallf){ //Die Maximale Zeit ist abgelaufen es gibt Alarm
digitalWrite(7,HIGH);
digitalWrite(8,LOW);
digitalWrite(13,HIGH);
tone(9,330);
delay(250);
digitalWrite(8,HIGH);
digitalWrite(7,LOW);
noTone(9);
delay(250);
previousMillis = millis(); //Sorgt dafür das der millis()Wert in previousMillis auf Null ist wenn wieder eingeschaltet wird
istGesetzt = true;
noTone(9);
