Temprature sensor guide
I am 14 years old and a beginner and i new to sensors so please can any bod give me guidance Regarding how to turn on and off a led when i reach a specific temperature For Example when its 50 Celsius led turns off else it keep on.
int pin = 0;
int tempc = 0;
int samples [5];
int i ;// variable
void setup(){
  Serial.begin (9600); // is used to activate serial comunication via usb
void loop(){
  //this equation is used to calculate the temp using 5v as reference
  for (i= 0 ; i<=4;i++){
    samples[i] = (5.0 * analogRead(pin)*100.0)/1183.0;//1023
    tempc = tempc + samples[i];
    delay(50);
    tempc= tempc/5.0;
Serial.println ("celsious"); // celcious is what this temperature represent
    Serial.println (tempc,DEC); //this is used so that the serial is show what to write in this case it is temperature
    delay (50); //0.5 miliseconds
I'm not clear whether you actually have a sensor - if so please tell us what it is.
If you are wondering what sensor to use I suggest you consider either an LM35 or LM335. They are cheap and very easy to use.
...R
Hi, You need to use an if.. else statement
if temp is greater than 50 turn LED FF else turn LED ON
https://www.arduino.cc/en/Reference/Else
will help..
As Robin2 has asked, what are you using to sense temp.
Tom... :)
Most simple case
 digitalWrite(ledPin, tempc > 50);
