TempReader library not working on supported board
I am trying to control a PWM fan on a Arduino Nano. I haven't attched the fan or the control code yet, as I'm testing the method of reading chip temperature first
I have just tried the TempReader test code, however it is reading -23C and 1C when it is 30C ambient temperature.
Not really sure why, the Nano is supposed to be supported by the library.
Here is the example code:
*   An example code to demonstrate the use of TempReader library.
*   This program prints the chip temperature to the serial monitor at every 0.5sec interval.
// Import TempReader
#include <TempReader.h>
// Create an object of TempReader
TempReader t;
  // Initialise Serial Communication
  // Read the temperature value in degree celsius
  int temp = t.ReadTempinC();
  // Display the value in the serial monitor
  Serial.print("Chip temperature is ");
  Serial.print(temp);
  Serial.println(" degrees Celsius");
What thermometer? Show a wiring diagram. You know the procedure. "-23" looks like a max negative value, like it is not providing an output.
Bare board - the TempReader library (supposedly) measures the internal chip temperature.
https://docs.arduino.cc/libraries/tempreader/
Of a nano?
I read your link. I did not know.
According to the official documentation on the Arduino website, yes!
Is your board legit or knockoff?
A knockoff but I did confirm, it is a ATMEL ATMEGA328P.
On an original Uno, it is also incorrect, reading 16C. I find it doubtful the chip is cooler than the ambient temperature by THAT much
It seems the internet has this code for calibrating the reading:
The library does not use the "delay()" for voltage stabilization:
Interesting. How would I be able to do an automatic calibration rather than basically guessing till I get it right?
Very good question. I will be searching.
I am also curious how it is done with the LM35/LM36 and DHT. I assume (but not sure) it is factory calibrated and creates voktage changes per partial unit of temperature.
