Entire script code so far
#include <Wire.h>
#include <LCD.h>
#include "SevenSegmentTM1637.h"
#include "SevenSegmentExtended.h"
#include <OneWire.h>
#include <DallasTemperature.h>
// All the LCD STUFF
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
//Temperature sTUFF
#define ONE_WIRE_BUS 6
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float tempC = 0;
float tempC1 = 0;
int oilWarningTemp = 27;
//7Segment stuff
//1st Display
const byte PIN_CLK = 10; // define CLK pin (any digital pin)
const byte PIN_DIO = 11; // define DIO pin (any digital pin)
SevenSegmentExtended display1(PIN_CLK, PIN_DIO);
//2nd Display
const byte PIN_CLK1 = 12; // define CLK pin (any digital pin)
const byte PIN_DIO1 = 13; // define DIO pin (any digital pin)
SevenSegmentExtended display2(PIN_CLK1, PIN_DIO1);
//Buttons
pinMode(4, INPUT_PULLUP);
// pinMode(11, INPUT_PULLUP);
// pinMode(10, INPUT_PULLUP);
//7 Segment Setup stuff
//Display1
display1.begin(); // initializes the display
display1.setBacklight(100); // set the brightness to 100 %
display1.print("HIYA"); // display INIT on the display
delay(1000); // wait 1000 ms
//Display1
display2.begin(); // initializes the display
display2.setBacklight(100); // set the brightness to 100 %
display2.print("LOVE"); // display INIT on the display
//LED's
pinMode(5, OUTPUT); //-Go Button
pinMode(7, OUTPUT); //-B2 Button
pinMode(9, OUTPUT); //-B2 Button
//Initialise LCD
lcd.begin (20, 4);
// Switch on the lcd backlight
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
//Relay Startup stuff
#define RELAY_ON 0
#define RELAY_OFF 1
//Relay Pin Numbers
#define Relay_1 2 // Arduino Digital I/O pin number
#define Relay_2 3 // Arduino Digital I/O pin number
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
delay(1000); //Check that all relays are inactive at Reset
//Temp setup stuff
sensors.begin();
pinMode(3, OUTPUT);
analogWrite(3, 0);
// LCD First Power Up Messages
lcd.print(" The Developist");
lcd.setCursor ( 0, 2 ); // go to the 2nd line
lcd.print(" *Select Program*");
lcd.setCursor ( 0, 3 ); // go to the 2nd line
lcd.print(" C41-E6-BW-Stand");
//Turn on Button LED's
digitalWrite(5, HIGH); // Turn on the LED
digitalWrite(6, HIGH); // Turn on the LED
digitalWrite(7, HIGH); // Turn on the LED
if (digitalRead(4) == LOW) {
//Button one is pressed!
lcd.clear();
lcd.print("C41 Process");
digitalWrite(5, LOW);
digitalWrite(7, LOW);
delay(5000);
Program1();
if (digitalRead(11) == LOW) {
//Button two is pressed!
lcd.clear();
lcd.print("E6 Process");
digitalWrite(6, LOW);
delay(5000);
Program1();
delay(100);
//temp loop stuff
sensors.requestTemperatures();
tempC = sensors.getTempCByIndex(0);
tempC1 = sensors.getTempCByIndex(1);
Serial.println(tempC);
Serial.println(tempC1);
// - Start of all the programs
void Program1() {
lcd.clear();
lcd.print("Set Temp to 38c");
lcd.setCursor ( 0, 1 ); // go to the 2nd line
lcd.print("Press when Ready");
while (digitalRead(4) == HIGH) {
// Do nothing
lcd.clear();
lcd.print("Sequence GO!");
delay(3000);
lcd.clear();
lcd.setCursor ( 0, 0 );
lcd.print("Developing Cycle");
c41DevCycle();
delay(10000);
lcd.clear();
digitalWrite(6, LOW); // Turn on the LED
lcd.print("Program Finished");
void c41DevCycle() {
uint8_t c41Devcountdown = 180;
uint8_t c41relayCountdown = 15;
bool runningc41Dev = true;
bool updateDisplayc41Dev = true;
uint32_t countdownTimec41Dev = millis();
uint32_t relayOnTimec41Dev = 5;
uint32_t relayOffTimec41Dev = 25;
bool relayStatec41Dev = true;
//-enter the servo function below
functionOn();
while (runningc41Dev) {
if (updateDisplayc41Dev) {
updateDisplayc41Dev = false;
lcd.setCursor(0, 2);
char m[3];
char s[3];
sprintf(m, "%02d", int(c41Devcountdown / 60));
sprintf(s, "%02d", c41Devcountdown % 60);
lcd.print(m);
lcd.print(":");
lcd.print(s);
//Below is the countdown in minutes and seconds for 7segment display
byte c41Devminutes = (c41Devcountdown / 60);
byte c41Devseconds = (c41Devcountdown % 60);
display1.printTime(c41Devminutes, c41Devseconds, true); // display time
if (relayStatec41Dev) {
lcd.print(" Agitating");
else {
lcd.print(" Standing");
lcd.setCursor(0, 4);
lcd.print("AGI stops in ");
else {
lcd.print("Next AGI in ");
sprintf(s, "%02d", c41relayCountdown);
lcd.print(s);
// Every second: count down.
if (millis() - countdownTimec41Dev > 1000) {
if (c41Devcountdown == 0) { // Finished! (this happens after the last second has passed).
runningc41Dev = false;
c41Devcountdown--;
c41relayCountdown--;
countdownTimec41Dev += 1000;
if (c41relayCountdown == 0) { // Switch the relay.
//enter the servo off function below
functionOff();
relayStatec41Dev = false;
c41relayCountdown = relayOffTimec41Dev;
else {
//enter the servo on function below
functionOn();
c41relayCountdown = relayOnTimec41Dev;
lcd.clear();
display1.clear();
void e6DevCycle() {
uint8_t e6Devcountdown = 120;
uint8_t e6relayCountdown = 5;
bool runninge6Dev = true;
bool updateDisplaye6Dev = true;
uint32_t countdownTimee6Dev = millis();
uint32_t relayOnTimee6Dev = 5;
uint32_t relayOffTimee6Dev = 25;
bool relayStatee6Dev = true;
digitalWrite(Relay_1, RELAY_ON); //--Insert here if you want the relay turned on at the start
while (runninge6Dev) {
if (updateDisplaye6Dev) {
updateDisplaye6Dev = false;
char m[3];
char s[3];
sprintf(m, "%02d", int(e6Devcountdown / 60));
sprintf(s, "%02d", e6Devcountdown % 60);
lcd.print(m);
lcd.print(":");
lcd.print(s);
if (relayStatee6Dev) {
else {
else {
sprintf(s, "%02d", e6relayCountdown);
lcd.print(s);
if (millis() - countdownTimee6Dev > 1000) {
if (e6Devcountdown == 0) { // Finished! (this happens after the last second has passed).
runninge6Dev = false;
e6Devcountdown--;
e6relayCountdown--;
countdownTimee6Dev += 1000;
if (e6relayCountdown == 0) { // Switch the relay.
relayStatee6Dev = false;
e6relayCountdown = relayOffTimee6Dev;
else {
e6relayCountdown = relayOnTimee6Dev;
lcd.clear();
void functionOn() {
digitalWrite(9, HIGH);
void functionOff() {
digitalWrite(9, LOW);
