hello, i have each character form the serial port being saved into a char. how to i test each bit of that char to see if its a 1 or 0 so i can shift the byte out to a shift register. Thank you.
here is what i have so far: void setup() { // put your setup code here, to run once: pinMode(4, OUTP - Pastebin.com
Welcome to the forum
Take a look at the bitRead() function
Why do you need to test each bit before shifting the byte to a shift register ?
so i know weather to set the data line high or low. i think bitRead() will work thank you.
Take a look at the shiftOut() function
That function is exactly what i need, thank you!
It's almost as though it was written for it
