Test if a string contains a string
Hi :slight_smile:
I'm trying to use a GSM shield to do different operations sent via sms. The contents of the sms is stored in a string. If the SMS contains certain words, certain tasks are to be performed.
I tried doing this with the strstr() function, but I'm not sure how to use it as a boolean, since the function returns pointers. If the word to look for is not found in the string to search, it returns a null pointer.
If I write
If(strstr(smsbuffer,"codeword"){do stuff;}
that always returns as true, whether the sms contained the word or not. Apparently the null pointer is not equal to zero. How should I do this? Is there a better way than strstr()?
See strstr()
Yes, that is the function I'm using, as you can see if you read my post above :).
My question is how I get that function to work as a boolean. Or if there is a better function to use.
Return Value
A pointer to the first occurrence in str1 of the entire sequence of characters specified in str2, or a null pointer if the sequence is not present in str1
Yes, I read that. I'm afraid I don't quite understand the concept of "Null pointer" and how to test if that's what's beeing returned though. It is apparently not the same as 0, or the finction I wrote above should work. Neither can I write
if(!(strstr(smsbuffer,"codeword")=NULL)){dothestuff;}
since that just gives me the old "left operand" error.
So the short version of my question is: how do I test the function strstr() to see if it returns a null pointer?
'=' is an assignment. '==' to test for equality.
Oh god. I wish this thread was deleted and never spoken about again. I wish I could do to it what Terry Pratchett posthumously did to his hard drive: run it over with a steamroller.
This is what happens when you take a few months off coding and wasn't very good at it to begin with. Sorry for wasting time and forum space with my brain fart.
Mixe:
NO, this is what happens when you don't expend any effort in debugging your code.
Paul
