Test Ublox M8N GPS and compass with arduino
Hi All
Have a nice day
Does any one should have write a program to test Ublox M8N GPS and compass modue
I need to test whether compass is working with arduino
see the following link for exact module
https://www.google.lk/search?q=ublox+m8n+compass&hl=en&site=webhp&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi0z9my_onTAhXHuY8KHWHWD8cQ_AUIBigB&biw=1280&bih=807#imgrc=Zf6qDGxP67dJCM:
You want us to provide you with code for a picture of a GPS? Get real!
NeoGPS is the only library that will parse the GNRMC etc. sentences from these newer GPS devices. It has several examples you can use to test the GPS device.
If your board does not have a second serial port to connect to the GPS device, be sure to use AltSoftSerial. It requires 2 specific pins on each kind of board (8 & 9 on an UNO). If those pins aren't available, try my NeoSWSerial. It supports baud rates 9600, 19200 and 38400. These two libraries are much more efficient than SoftwareSerial.
Google can help you find a library for the compass, and it surely has example programs.
PaulS:
No
Really I have GPS module which is attached to the my fist post
That GPS module has GPS + Compass
The Compass data out based on I2C format
So I need to test that compass is working
Please advice
/dev:
Dear Thanks for the info
Actually I need to text compass which is built in GPS module and Compass output is I2C format so does NeoGPS support to compass
Please advice
Thanks in advance
Thanks to all
I have found following link so it will be solved
Thanks
