Test
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define RELAY 3 //connect the relay to number 3 pin
#define BUZZER 2 // connect the buzzer to 2 pin
#define ACCESS_DELAY 2000
#define DENIED_DELAY 1000
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
pinMode(RELAY, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
digitalWrite(RELAY, HIGH);
Serial.println(“Put your card to the reader for scanning …”);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print(“UID tag :”);
String content= “”;
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? ” 0″ : ” “);
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? ” 0″ : ” “));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print(“Message : “);
content.toUpperCase();
if (content.substring(1) == “AB CD EF GH”) // enter your own card number after copying it from serial monitor
Serial.println(“Authorized access”);
digitalWrite(RELAY, LOW);
delay(ACCESS_DELAY);
else {
Serial.println(” Access denied”);
tone(BUZZER, 300);
delay(DENIED_DELAY);
noTone(BUZZER);
(Code tags added by moderator - next post, use the </> button and paste your code in the box that opens)
Please use the IDE Autoformat function and code tags. You fund that un the first topic named "How to use this Forum", #7.
Test failure. Lack of code tags causes code to be interpreted as containing italics and removal of array indexes. Read the forum guidelines to see how to post code.
Is there a question?
And the point of this is?
Paul__B:
A mathematical point having no width, no height, no length, covering no surface, no volume?
Railroader:
A singularity?
SteveMann:
A singularity?
That's also possible.
Is a singularity really dimensionless or do quantum effects prevent that? And in any case distance is relative, the universe is a dimensionless, timeless point to light.
