I am trying to hook up a Decoder/Demultiplexer in order to multiply the number of outputs from the microcontroler. Here is the schematic:
I supply 5V to VCC and to one of the input pins. However all the output pins (0-15) remain HIGH. I would expect that I should be reading LOW on pad X1? What am I missing here?
So the device is working as designed. From the description of the device:
Each or these 4-line-to-16-line decoders utilizes TTL circuitry to decode four binary-coded inputs into one of sixteen mutually exclusive outputs when both the strobe inputs G1 and G2 are low The demultiplexing function is performed by using the 4 input lines to address the output line passing data from one of the strobe inputs with the other strobe input low **When either strobe input is high all outputs are high **
It's a link to a web image. You do not need to download anything. "Insert an image" icon doesn't allow to post an image. It asks to provide a link to the picture. At least this is my understanding.
