Testing for the existence of a sensor
I'm trying to use an ee892 CO2 sensor in a project I'm working on. It uses a proprietary low speed derivative of I2C but it's not compatible with the I2C bus. Can you give me some ideas on how I could test to see if this thing is alive?
How do I strobe a pin to send a bunch of data then wait for a certain period for a reply before moving on? It's the waiting for the reply part that I'm having problems with.
Hard to believe that you've never heard of delay().
The "See also" section is interesting, too.
daemach: Can you give me some ideas on how I could test to see if this thing is alive?
Can you give a link to the datasheet?
Look into shiftOut() and SoftwareSerial. to communicate with a serial device, you need Clock, Enable and Data. So you need : What clock frequency or baud rate, enable ( 0 or 1 ) and the type of data format ( 1 start bit, 8 data bits, 1 stop bit , 1 parity bit ) ← example. If those instructions it is not working, you have to “homemade” a function to generated the proper clock/data.
my 2 cents.
