Hello all
I've been writing a relatively large program to control an RGB LED in various different ways. A significant part of this program is to be able to convert a single numerical value to three values in an array (red green and blue). For this I have attempted to create my own function to fulfill this purpose.
However, this function has been returning incorrect values. I have placed it inside it's own script for testing purposes.
int CycleOut[] = {0, 0, 0};
void ValueToColour(int ColourNumber)
if (ColourNumber < 11) {
CycleOut[0] = map(ColourNumber, 0, 10, 20, 10);
CycleOut[1] = map(ColourNumber, 0, 10, 0, 10);
CycleOut[2] = 0;
else if (ColourNumber < 21) {
CycleOut[0] = map(ColourNumber, 11, 20, 9, 0);
CycleOut[1] = map(ColourNumber, 11, 20, 11, 20);
CycleOut[2] = 0;
Serial.begin(2000000);
if (Serial.available()) {
int CNum = Serial.read();
ValueToColour(CNum);
for (int i=0; i < 3; i++) {
Serial.println(CycleOut[i]);
I expect different values to be returned via serial when I input a value between 1-20 however instead I just receive 0. Any ideas?
On another note, I believe I should be using pointers in my function however I cannot get them to work without returning errors, any help on this would be greatly appreciated.
Serial.read(); return a char value.
You can try:
int CNum = Serial.parseInt();
to make your code works.
If these are the expected output values:
1: 19 1 0
2: 18 2 0
3: 17 3 0
4: 16 4 0
5: 15 5 0
6: 14 6 0
7: 13 7 0
8: 12 8 0
9: 11 9 0
10: 10 10 0
11: 9 11 0
12: 8 12 0
13: 7 13 0
14: 6 14 0
15: 5 15 0
16: 4 16 0
17: 3 17 0
18: 2 18 0
19: 1 19 0
20: 0 20 0
then there is nothing wrong with your function, tested as follows (but there are much easier ways to get those values):
CycleOut[2] = 0;
CycleOut[2] = 0;
for (int j = 1; j < 21; j++) {
Serial.print(j);
Serial.print(": ");
ValueToColour(j);
for (int i = 0; i < 3; i++) {
Serial.print(CycleOut[i]);
Serial.print(" ");
Check out Serial Input Basics.
Thank you for your help, and yes those are the expected values, however i am unable to see a functional difference between your code and mine that would prevent my code from working correctly. Could you clarify which part of my code prevents it from working as intended?
Edit: didn't read arduino_new's comment properly, thank you again, it works now
Here is a simpler approach to arrive at the same values (valid if 1 <= j <=20);
CycleOut[0] = 20-j;
CycleOut[1] = j;
CycleOut[2] = 0;
