Hi everyone,
I'm the programmer for my school's robotics club. This year, we've built a bot using Tetrix Mecanum wheels, running on Torquenado motors and programmed with a Prizm board. To control the wheels, we're using Tetrix's example tele-op Mecanum code (which can be found here and which requires the DC motor expansion controller library). For our controller, we're using a PS4 controller with tetrix's tele-op library.
One problem we've been encountering is that the code, after a certain period of driving, will stop responding, causing the bot to either stop driving or to keep driving in the direction that the stick was held as it locked up (usually leading to it driving until it hits a wall). I've asked many of the previous year's programmers about this, and I've tried debugging the values and whatnot, but nothing comes up. Keep in mind that the code fully stops responding, even other functions/lines in the code will not respond. Not sure if this is a hardware or software problem. The previous year's programmer told me that if the Prizm boards are powered by an undercharged battery it can affect the code execution, but if I take the driver's word for it this issue has happened a few times on charged batteries.
TLDR; mecanum wheels being controlled with PS4 controller. bug happens where code randomly stops in the middle of driving, causing bot to stop moving or to keep driving in one direction uncontrollably.
