Text is back to front
This what you're after?
TFT LCD Identifier
Unknown LCD driver chip: C0C0
If using the Adafruit 2.8" TFT Arduino shield, the line:
  #define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
(deleted)
http://www.ebay.co.uk/itm/Uno-TFT-2-8-inch-LCD-Display-Touch-Screen-Module-Transfer-PCB-Board-for-Arduino-/111674693701?hash=item1a00549845:g:q7UAAOSw~OdVcVF5
(deleted)
As I said before I have no idea about any of this, do you have a link to that library?
undescribed66: do you have a link to that library?
http://lmgtfy.com/?q=mcufriend+tft+arduino+library
Thank you :) however I still have the same problem with the text
(deleted)
(deleted)
LCD_ID_Reader.zip (2.94 KB)
Okay so I tried the attatched code.. the screen goes to a dimmed white with a black line on it and here is the serial monitor - Initializing LCD... Reading ID...0x0000 Loading LCD registers... Filling the screen... Done filling... If your screen filled red, you may be able to use the library at http://misc.ws
(deleted)
(deleted)
Sorry I’ve had a really important situation I had to nip off to… I will try it now
Omg you are such a legend! works perfectly now, thank you for sticking with me on this and being patient with me (sorry for my lack of knowledge) I hope you have a great end to your day :)
BTW, six hours really isn't very long to be debugging. Especially if the issue was well explained - I suspect the forum could have it figured out within 15 minutes.
A little patience and discipline goes a long way toward getting things solved!
Why not just mount your project in a box with a mirror?
I'm serious, BTW. If this display has firmware that prints characters in reverse, it might actually be intended to be mounted that way.
