text not fully printing out on program run
I have the following code:
  Arduino Motion Sensor Burglar Alarm Project
  by Arvind Sanjeev
  Please check out  http://diyhacking.com for the tutorial of this project.
  DIY Hacking
int speakerOut = 6;//Piezo buzzer's positive terminal is connected to digital pin 9
byte names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'};
int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
byte melody[] = "2d2a1f2c2d2a2d2c2f2d2a2c2d2a1f2c2d2a2a2g2p8p8p8p";
// count length: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
//                                10                  20                  30
int count = 0;
int count2 = 0;
int count3 = 0;
int MAX_COUNT = 24;
int statePin = LOW;
void siren();
volatile byte intruder;
  attachInterrupt(digitalPinToInterrupt(2), intruder_detect, RISING);//Initialize the intterrupt pin for the motion sensor (Arduino digital pin 2)
  intruder = 0;
void intruder_detect()//This function is called whenever an intruder is detected by the arduino
  intruder++;
  Serial.println("Intruder detected");
  for (int i = 0; i < 3; i++) //Play the alarm three times
    siren();
void siren()//This function will make the alarm sound using the piezo buzzer
  for (count = 0; count < MAX_COUNT; count++) {
    for (count3 = 0; count3 <= (melody[count * 2] - 48) * 30; count3++) {
      for (count2 = 0; count2 < 8; count2++) {
        if (names[count2] == melody[count * 2 + 1]) {
          analogWrite(speakerOut, 1023);
          delayMicroseconds(tones[count2]);
          analogWrite(speakerOut, 0);
        if (melody[count * 2 + 1] == 'p') {
          // make a pause of a certain size
          delayMicroseconds(100);
I noticed that only “In” gets printed out, then when the method siren is done, it prints out the rest. Why is this, and is there any way to fix this? Does this have to do with this language being (a)synchronous?
You should not use Serial.print or delay/delayMicroseconds in an interrupt routine.
In intruder_detect, only set intruder = 1;
Then in loop() you can test whether intruder is set. If it is, clear it, and also play the alarm three times.
Pete
Thanks, I made the changes, and it works now.
Why/how did it fix it? I would like to understand for future reference.
When intruder_detect executes, interrupts are switched off. The Serial.println seems to have enough time to send two characters, but with interrupts off it can't send any more. Your interrupt routine then calls siren() three times (while interrupts are still off) so nothing more is printed until siren is finished, at which point intruder_detect terminates, interrupts are turned back on and the rest of the string is printed.
Pete
