Text on RGB (P6 ) Display using arduino Uno
I have tried adding library RGBMatrixPanel and tried executing examples .
I am not getting desired output on 32x32 RGB matrix.
Connection is also verified and following site referred .
https:https://cdn-learn.adafruit.com/downloads/pdf/32x16-32x32-rgb-led-matrix.pdf
Video : 32x16 RGB LED matrix display with Arduino UNO microcontroller | DFrobot - YouTube
Code : Colourwheel 32x32
// colorwheel demo for Adafruit RGBmatrixPanel library.
// Renders a nice circle of hues on our 32x32 RGB LED matrix:
// http://www.adafruit.com/products/607
// Written by Limor Fried/Ladyada & Phil Burgess/PaintYourDragon
// for Adafruit Industries.
// BSD license, all text above must be included in any redistribution.
#include <RGBmatrixPanel.h>
// Most of the signal pins are configurable, but the CLK pin has some
// special constraints.  On 8-bit AVR boards it must be on PORTB...
// Pin 8 works on the Arduino Uno & compatibles (e.g. Adafruit Metro),
// Pin 11 works on the Arduino Mega.  On 32-bit SAMD boards it must be
// on the same PORT as the RGB data pins (D2-D7)...
// Pin 8 works on the Adafruit Metro M0 or Arduino Zero,
// Pin A4 works on the Adafruit Metro M4 (if using the Adafruit RGB
// Matrix Shield, cut trace between CLK pads and run a wire to A4).
#define CLK  8   // USE THIS ON ARDUINO UNO, ADAFRUIT METRO M0, etc.
//#define CLK A4 // USE THIS ON METRO M4 (not M0)
//#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE   9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
  int      x, y, hue;
  float    dx, dy, d;
  uint8_t  sat, val;
  uint16_t c;
  matrix.begin();
  for(y=0; y < matrix.width(); y++) {
    dy = 15.5 - (float)y;
    for(x=0; x < matrix.height(); x++) {
      dx = 15.5 - (float)x;
      d  = dx * dx + dy * dy;
      if(d <= (16.5 * 16.5)) { // Inside the circle(ish)?
        hue = (int)((atan2(-dy, dx) + PI) * 1536.0 / (PI * 2.0));
        d = sqrt(d);
        if(d > 15.5) {
          // Do a little pseudo anti-aliasing along perimeter
          sat = 255;
          val = (int)((1.0 - (d - 15.5)) * 255.0 + 0.5);
        } else
          // White at center
          sat = (int)(d / 15.5 * 255.0 + 0.5);
          val = 255;
        c = matrix.ColorHSV(hue, sat, val, true);
        c = 0;
      matrix.drawPixel(x, y, c);
  // Do nothing -- image doesn't change
Please help me with getting text or desired output on display.
I gave you a Karma point for using code tags on your first post.
What is your question? Or more specifically, what are you getting that is incorrect?
Sir, I want a text to be displayed on RGB (P6) Module. I used a examples from library... but not getting any text Random colours are displayed on module.
SteveMann: I gave you a Karma point for using code tags on your first post.
Thanku Sir
Which arduino are you using? 32x32 RGB may exceed the available memory in an UNO, although I am not familiar with the P6 displays.
