Text wont display properly, but bitmaps do? Nano - LCD 19264-UC1609C
Hi there, I am trying to get text to display on this LCD however it always displays a strange symbol instead of proper text and I cannot figure out why this would be.
I am using the ERM19264_UC1609 library on an Arduino Nano Clone. I believe all my connections should be correct as it works fine on any other example files such as the bitmap one. But the text does not seem to work.
I have tried to connect it with Hardware SPI and Software SPI with the same results on both. I have also tried different Arduino Nano boards and different defined pins with no change. I am also just using the default example sketch.
If anyone could give me a suggestion to fix that would be great, thank you!
Symbols instead of text displayed:
Example code:
	@file  ERM19264_UC1609_SWSPI.ino
	@brief  Example file for ERM19264_UC1609 library, showing use of software SPI  mode
	only difference for user is the constructor used when you instantiate the object and pin definations
	@author Gavin Lyons
	@details
    <https://github.com/gavinlyonsrepo/ERM19264_UC1609>
	@note
		-# (1) GPIO is for arduino UNO for other tested MCU see readme.
		-# (2) This is for software  SPI for hardware SPI see all other examples.
	@test
		-# 601 Software SPI
#include <ERM19264_UC1609.h>
// LCD setup
// GPIO 5-wire SPI interface
#define CD 10 // GPIO pin number pick any you want
#define RST 9 // GPIO pin number pick any you want
#define CS 8  // GPIO pin number pick any you want
#define SCLK 13 // GPIO pin number pick any you want
#define DIN  11 // GPIO pin number pick any you want
// SW SPI GPIO delay uS. May have to be increased for high freq CPU, 0 by default.
uint16_t SW_SPI_GPIO_Delay = 0 ;
#define LCDCONTRAST 0x49 // contrast: Range 0-0xFE, optional, default 0x49
#define LCDRAMADDRCTRL 0x02  // RAM address control: Range 0-0x07, optional, default 0x02
#define MYLCDHEIGHT 64
#define MYLCDWIDTH  192
#define FULLSCREEN (MYLCDWIDTH * (MYLCDHEIGHT/8)) // 1536 bytes
// define a buffer to cover whole screen
uint8_t  screenBuffer[FULLSCREEN];
uint8_t  fullScreenBuffer[(MYLCDWIDTH * (MYLCDHEIGHT/8))]; // 1536 bytes
// instantiate object pick any GPIO you want
ERM19264_UC1609  mylcd(MYLCDWIDTH , MYLCDHEIGHT, CD, RST, CS, SCLK, DIN );
// Instantiate  a screen object, in this case to cover whole screen
ERM19264_UC1609_Screen fullScreen(fullScreenBuffer, MYLCDWIDTH, MYLCDHEIGHT, 0, 0);
// Varibles to control test timing
long startTime ;                    // start time for stop watch
long elapsedTime ;                  // elapsed time for stop watch
// ************* SETUP ***************
  delay(50);
  mylcd.LCDbegin(LCDCONTRAST, LCDRAMADDRCTRL); // initialize the LCD
  mylcd.LCDFillScreen(0x00, 0); // Clear the screen
  startTime = millis();
  mylcd.LCDHighFreqDelaySet(SW_SPI_GPIO_Delay);
// ************** MAIN LOOP ***********
 // Call a function to display text
  DisplayText();
// ************** END OF MAIN ***********
void DisplayText()
  int count = 0;
  mylcd.setTextColor(FOREGROUND);
  mylcd.setTextSize(1);
  mylcd.ActiveBuffer =  &fullScreen;
  mylcd.LCDclearBuffer(); // Clear the buffer
  while (1)
    mylcd.setCursor(20, 10);
    mylcd.print(F("Software SPI speed test"));
    mylcd.setCursor(20, 30);
    mylcd.print(mylcd.LCDHighFreqDelayGet());
    mylcd.setCursor(20, 50);
    if (count < 1000)
      mylcd.print(count);
    } else
      elapsedTime =   millis() - startTime;
      mylcd.print("Time Taken:");
      mylcd.print(elapsedTime / 1000L);
    delay(1);
    mylcd.LCDupdate();  // Write to the buffer
    if (count == 1000)
      while (1) {
      }; //test finished
    count ++;
Bitmap Example Sketch - Works fine?:
The text example shows these commented-out...
// GPIO pin number SCK(UNO 13) , HW SPI , SCK
// GPIO pin number SDA(UNO 11) , HW SPI , MOSI
Hi thank you for the response, yes it is commented out but it is the same on the bitmap example code and that one still works fine. I found that the default hardware SPI pins on an arduino nano are 13 and 11, so I assumed that would be set by default.
If you uncomment them it either gives an error or does nothing if you define them.
Thank you for linking the file too, I have tried the other fonts and have uncommented them in ERM19264_graphics_font.h but I still get nothing or the weird symbol.
I appreciate the response, would you have any other suggestions on how I would fix this issue?
Thanks!
There is a note in your link about screens not initializing and adjusting the RAM address...
Did you find a solution to this problem?
I just started experimenting with this display, running into exactly the same problem as you; everything except text seems to work ok.
No sorry, none of the solutions seemed to make it work. I just gave up on it. If you find one please let me know.
If I get the time this evening, I might submit an issue on github. The reason I looked into the repo was that I plan to write a Rust library to work together with the embedded_graphics - Rust crate. So I needed to understand what needs to be done. :slight_smile:
