gc9n
March 27, 2013, 3:26pm
1
Is there any way to use the TextFinder with a String variable?
for example, i want for every word of "A" char to get the value of it.......
this code doesnt work as you understand..
String mystringvar = "A1=54$A2=23$A3=32";
TextFinder finder(mystringvar );
while(finder.findUntil("A", "\n\r")){
int val = finder.getValue();
Serial.print(val ); Serial.print(",");
i want to get 54,23,32
You can maybe use strtok() to split the string into smaller parts and then use indexOf() to filter out the rest.
Try this, http://arduino.cc/en/Tutorial/StringIndexOf
gc9n
March 27, 2013, 4:02pm
3
so there isn't any function or something to do this for string variables?
system
March 27, 2013, 4:05pm
4
Get your shift key unstuck. Are you talking about Strings or strings? They are NOT interchangeable.
And, you can't use strtok() on a String.
gc9n
5
i am talking about Strings
i think this might work..
char* subStr (char* str, char *delim, int index) {
char *act, *sub, *ptr;
static char copy[MAX_STRING_LEN];
int i;
// Since strtok consumes the first arg, make a copy
strcpy(copy, str);
for (i = 1, act = copy; i <= index; i++, act = NULL) {
//Serial.print(".");
sub = strtok_r(act, delim, &ptr);
if (sub == NULL) break;
return sub;
