Hi All,
I am building a light ring for my DSLR using a 24 LED Neopixel ring.
What i want to achieve is to use a UNO with a TFT 2.4 touchscreen to change the color/intensity of the light.
I found a sketch doing this with a MEGA2560, but was unable to have it work....
TFT tested with the sample sketchs in Arduino IDE, works fine on bot Uno and MEGA 2560.
Didi anyone build something similar and is ready to share the sketch?
Here is the sketch for the MEGA (Which does not work on my side).
Thanks for your help!
#include <math.h>
#include <SPFD5408_Adafruit_GFX.h> // Core graphics library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPFD5408_TouchScreen.h>
// *** SPFD5408 change -- End
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
#define YP A1 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 6 // can be a digital pin
#define PIN 53
#define NUM_LEDS 24
#define BRIGHTNESS 80
// Calibrate values
#define TS_MINX 125
#define TS_MINY 85
#define TS_MAXX 965
#define TS_MAXY 905
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A4
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define YELLOW 0x001F
#define GREEN 0xF800
#define RED 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define BLUE 0xFFE0
#define WHITE 0xFFFF
void EmitCyan();
void EmitWhite();
void EmitGreen();
void EmitYellow();
void EmitPink();
void EmitBlack();
uint16_t width = 0;
uint16_t height = 0;
uint16_t x = 40;
uint16_t y = height - 20;
uint16_t w = 75;
uint16_t h = 20;
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
#define BOXSIZE 40
#define PENRADIUS 3
#define BUTTONS 9
#define BUTTON_Red 0
#define BUTTON_DarkRed 1
#define BUTTON_RED 2
#define BUTTON_DarkGreen 3
#define BUTTON_DeepRed 4
#define BUTTON_Blue 5
#define BUTTON_LightBlue 6
#define BUTTON_LightBlue1 7
Adafruit_GFX_Button buttons[BUTTONS];
uint16_t buttons_y = 0;
#define MINPRESSURE 10
#define MAXPRESSURE 1000
Serial.println(F("Paint!"));
tft.reset();
tft.begin(0x9341); // SDFP5408
strip.begin();
strip.show(); // Initialize all pixels to 'off'
tft.setRotation(0); // Need for the Mega, please changed for your choice or rotation initial
tft.fillScreen(BLACK);
tft.setCursor (40, 20);
tft.setTextSize (5);
tft.setTextColor(WHITE);
tft.println("COLORS");
tft.setCursor (65, 85);
width = tft.width() - 1;
height = tft.height() - 100;
initializeButtons();
showCalibration();
// Test of calibration
int i = 0;
TSPoint p;
// Wait a touch
digitalWrite(13, HIGH);
p = waitOneTouch();
digitalWrite(13, LOW);
p.x = mapXValue(p);
p.y = mapYValue(p);
for (uint8_t b = 0; b <BUTTONS; b++) {
if (buttons[b].contains(p.x, p.y)) {
// Action
switch (b) {
case BUTTON_Red:
EmitPink();
showCalibration();
case BUTTON_DarkRed:
EmitCyan();
showCalibration();
case BUTTON_RED:
EmitBlack();
showCalibration();
case BUTTON_DarkGreen:
EmitGreen();
showCalibration();
case BUTTON_Blue:
EmitBlue();
showCalibration();
case BUTTON_LightBlue:
EmitYellow();
showCalibration();
case BUTTON_DeepRed:
EmitDeepRed();
showCalibration();
void initializeButtons() {
uint16_t x = 40;
uint16_t w = 75;
uint16_t h = 40;
uint8_t spacing_x = 5;
uint8_t textSize = 2;
char buttonlabels[7][20] = {"PINK", "CYAN", "WHITE", "GREEN", "RED", "BLUE", "YELLOW"};
uint16_t buttoncolors[15] = {RED, GREEN, BLACK, MAGENTA, CYAN, BLUE, YELLOW};
for (uint8_t b = 0; b < 9; b++) {
if (b < 3)
buttons[b].initButton(&tft, // TFT object
x + b * (w + spacing_x), y, // x, y,
w, h, BLACK, buttoncolors[b], WHITE, // w, h, outline, fill,
buttonlabels[b], textSize);
Serial.print( h);
}// text
if (b == 3)
uint16_t x = 40;
uint16_t y = height + 30 ;
uint16_t w = 75;
uint16_t h = 40;
x + 0 * (w + spacing_x) , y, // x, y,
if (b == 4)
uint16_t x = 40;
uint16_t w = 75;
uint16_t h = 40;
x + 1 * (w + spacing_x) , y, // x, y,
if (b == 5)
uint16_t x = 40;
uint16_t w = 75;
uint16_t h = 40;
x + 2 * (w + spacing_x) , y, // x, y,
if (b == 6)
uint16_t x = 40;
uint16_t y = height + 80 ;
uint16_t w = 75;
uint16_t h = 20;
w, h,BLACK, buttoncolors[b], WHITE, // w, h, outline, fill,
if (b == 7)
uint16_t x = 40;
uint16_t w = 75;
uint16_t h = 40;
// Save the y position to avoid draws
buttons_y = y;
// Map the coordinate X
uint16_t mapXValue(TSPoint p) {
uint16_t x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
//Correct offset of touch. Manual calibration
//x+=1;
return x;
uint16_t mapYValue(TSPoint p) {
uint16_t y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
//y-=2;
return y;
TSPoint waitOneTouch() {
TSPoint p;
do {
p = ts.getPoint();
pinMode(XM, OUTPUT); //Pins configures again for TFT control
pinMode(YP, OUTPUT);
} while ((p.z < MINPRESSURE ) || (p.z > MAXPRESSURE));
return p;
void showCalibration() {
tft.setCursor (40, 0);
for (uint8_t i = 0; i < 8; i++) {
buttons[i].drawButton();
void EmitDeepRed()
for(int i=0;i<30;i++)
strip. setPixelColor(i, 255, 0, 0);
strip.show();
void EmitCyan()
strip. setPixelColor(i,0, 255, 255);
strip.show();
void EmitWhite()
strip. setPixelColor(i,255, 255, 255);
strip.show();
void EmitGreen()
strip. setPixelColor(i,0, 255, 0);
strip.show();
void EmitBlue()
strip. setPixelColor(i,0, 0, 255);
strip.show();
void EmitYellow()
strip. setPixelColor(i,255, 255, 0);
strip.show();
void EmitPink()
strip. setPixelColor(i,255, 0, 255);
strip.show();
void EmitBlack()
strip.show();
