Hello,
I am currently making following program:
#include "Arduino.h"
#include <Adafruit_TFTLCD.h>
#include <Adafruit_GFX.h>
#include <TouchScreen.h>
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
#define YP A2 // must be an analog pin, use "An" notation!
#define XM A3 // must be an analog pin, use "An" notation!
#define YM 8 // can be a digital pin
#define XP 9 // can be a digital pin
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
boolean buttonEnabled = true;
int currentPage = 0;
Serial.print("Starting...");
tft.reset();
tft.begin(tft.readID());
tft.setRotation(1);
drawHome();
void drawHome()
tft.fillScreen(BLACK);
//Draw white frame
tft.drawRect(0, 0, 319, 240, WHITE);
//Print "Hello" Text
tft.setCursor(100, 30);
tft.setTextColor(WHITE);
tft.setTextSize(4);
tft.print("Hello");
//Print "YouTube!" text
tft.setCursor(80, 100);
tft.setTextColor(RED);
tft.setTextSize(4);
tft.print("YouTube!");
//Create Red Button
tft.fillRect(60, 180, 200, 40, RED);
tft.drawRect(60, 180, 200, 40, WHITE);
tft.setCursor(80, 188);
tft.setTextSize(3);
tft.print("Subscribe!");
TSPoint p = ts.getPoint(); //Get touch point
if (p.z > ts.pressureThreshhold)
Serial.print("X = ");
Serial.print(p.x);
Serial.print("\tY = ");
Serial.print(p.y);
Serial.print("\n");
p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
if (p.x > 60 && p.x < 260 && p.y > 180 && p.y < 220 && buttonEnabled
&& currentPage == 0) // The user has pressed inside the red rectangle
buttonEnabled = false; //Disable button
//This is important, because the libraries are sharing pins
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
//Erase the screen
//Draw frame
tft.setCursor(50, 50);
tft.setTextSize(3);
tft.print("Thank you for\n\n subscribing!");
currentPage = 1;
delay(10);
if (p.x > 0 && p.y > 0 && currentPage == 1)
currentPage = 0;
drawHome();
The writing and the subscribe button is exactly there where it supposed to be, but somehow when I try to press the button, it does not work. It only works when I press in the black between "Hello" and "YouTube!" at the coordinates around X = 529 Y = 353, which the serial monitor showed me.
So what is the exact problem here? How can it be that the pixel are read wrong, but to draw and write stuff on the display the normal coordinates are actual working?
