Hello
I tried to compile example from this library for 480x320 display
Example name: GLUE_DEMO_480x320
Error says:
GLUE_Demo_480x320:21:19: error: 'A2' was not declared in this scope
UTFTGLUE myGLCD(0,A2,A1,A3,A4,A0); //all dummy args
GLUE_Demo_480x320:21:22: error: 'A1' was not declared in this scope
exit status 1
Can someone tell me what is the problem?
Thanks!
zglibeti:
Yes. You are not using an Arduino.
Regular Arduinos have "known" Analog pins called A0, A1, ...
In fact A2 is only a dummy. You could equally well write:
UTFTGLUE myGLCD(0,0,0,0,0,0); //all dummy args
There are other examples where A1, A2 are actually important e.g. Touch pins on Mcufriend shields.
David.
Okay David,
Thank you very much
Should I write pins which are used on esp32?
Shields mate with headers on TTGO / Wemos R32 boards. (you still need a small hardware mod)
If you want to hand-wire to a different ESP32 board you will have to follow the same Wemos scheme.
It looks as if the Calibration sketch even specifies the ESP32 pins.
If you have a problem, please provide information.
I do not expect to support random hand-wiring. But I will certainly help with R32 boards.
David.
