TFT 320QVT problem +pedal
A few months ago i decided to build a guitar pedal like:
ElectroSmash - pedalSHIELD Arduino Guitar Pedal. with the addition of a 3.2in tft touchsreen...
ive gotten it to work right without the touchscreen.. but i cant get the tft working... im 90% sure it is wired correctly and i think there may be a problem with the code itself...
the tft im using is the 320QTV and when i upload the code the L - Led on the arduino remains on like when theres no code... according to the new code it should not be on...
also my tft has a F-CS pin that i have no idea where it goes... ive connected the CS, and T-CS... and left the SD-CS and its other pins unconnected for now..
Ive used various code examples and its connected as : 38, 39, 40, 41 and the touch is:42, 43, 44, 45, 46 (instead of 6, 5, 4, 3, 2)
All i get is a white screen.
Any help would be appreciated
I have no clue what the pictures were supposed to tell us. I have no clue which touch screen you are using, because you did not provide a link. I have no idea what code you are using, because you didn't post it. I have no idea what "its connected as : 38, 39, 40, 41 and the touch is:42, 43, 44, 45, 46 (instead of 6, 5, 4, 3, 2)" means.
The only part of your post that does mean anything is
What that means is that your code is not correct or your wiring is wrong.
I have wired it according to this:
https://forum.arduino.cc/index.php?topic=101029.0
The code i tryed was the examples the tft and touch librarys come with... the only thing i change is the pins for the touch...
The pins RS, WR, CS, &RSET are set(wired) to pins 38, 39, 40, 41
& touch is: DCLK(T_CLK),
CS (T_CS),
IN (T_DIN),
OUT(T_DO),
IRQ (T_IRQ) is wired as pins 42, 43, 44, 45, 46
And as i said i left the SD unconnected.... and theres an F_CS that i dont know where it goes... googled that the code should start like follows:
UTFT myGLCD (SSD1289, 38, 39, 40, 41)
And gain all i get is a white screen...
This is the pinnout on my tft... any idea what the F_SC does(5 down from the left)
