TFT 9341 issues
Can anyone help me with this problem:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino: In function 'void drawButtons()':
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:75:28: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print("0", 267, 87);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:81:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print("Clear", 40, 147);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:86:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print("Enter", 190, 147);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino: In function 'void updateStr(int)':
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:103:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print("BUFFER FULL!", CENTER, 192);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:105:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print(" ", CENTER, 192);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:107:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:109:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino: In function 'void loop()':
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:240:53: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myGLCD.print("BUFFER EMPTY", CENTER, 192);
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:242:53: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:244:53: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\EDABBS~1\AppData\Local\Temp\arduino_modified_sketch_460539\URTouch_ButtonTest.ino:246:53: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\edabbsvilciauskas\Documents\Arduino\libraries\UTFT\UTFT.cpp: In function 'drawPixel.constprop':
C:\Users\edabbsvilciauskas\Documents\Arduino\libraries\UTFT\UTFT.cpp:737:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See http://gcc.gnu.org/bugs.html for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Such a list or errors is produced when the Arduino compiler tries to convert a sketch into the long string of zeros and ones that subsequently are uploaded to the board. Without the source sketch is is impossible to [try to] find out what was not accepted by the compiler.
Please upload:
  1. A description of the hardware (what piece of hardware did you connect with what other piece, and how - wiring)
  2. A description of what you want to perform with that hardware
  3. The sketch itself.
There are enough sympathetic guys here on the forum that want to help you, but please give them the necessary information!
