Hello,
I"m new with the TFT touchscreens and I want to make a new interface to programm LED's with a touchscreen instead of IR.
I have a problem with my first Button... This is a simple ON/OFF switch. I want the button once pressed to change the background color and the text (Green/red and ON/OFF)
I first tried this first with the GFX ButtonClass, but I see no changes. I didn't find a function to do this in "Adafruit_GFX_Button Class Reference".
Then I tried to define the button myself, the switch works, but the screen lay-out is not changing. What I'm doing wrong?
Thanks for the advise
Jacques.
#include "Adafruit_GFX.h"
#include "MCUFRIEND_kbv.h"
#include "TouchScreen.h" // only when you want to use touch screen
// #include "bitmap_mono.h" // when you want to display a bitmap image from library
// #include "bitmap_RGB.h" // when you want to display a bitmap image from library
// #include "Fonts/FreeSans9pt7b.h" // when you want other fonts
// #include "Fonts/FreeSans12pt7b.h" // when you want other fonts
// #include "Fonts/FreeSerif12pt7b.h" // when you want other fonts
// #include "FreeDefaultFonts.h" // when you want other fonts
// #include "SPI.h" // using sdcard for display bitmap image
// #include "SD.h"
#define BLACK 0x0000
#define NAVY 0x000F
#define DARKGREEN 0x03E0
#define DARKCYAN 0x03EF
#define MAROON 0x7800
#define PURPLE 0x780F
#define OLIVE 0x7BE0
#define LIGHTGREY 0xC618
#define DARKGREY 0x7BEF
#define BLUE 0x001F
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define ORANGE 0xFD20
#define GREENYELLOW 0xAFE5
#define PINK 0xF81F
#define PI 3.1415926535897932384626433832795
#define YP A3 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 9 // can be a digital pin
#define XP 8 // can be a digital pin
#define MINPRESSURE 200
#define MAXPRESSURE 1000
#define TS_MINX 900
#define TS_MAXX 100
#define TS_MINY 70
#define TS_MAXY 900
int pixel_x, pixel_y; //Touch_getXY() updates global vars
// X en Y coordinaten hangen af van het scherm
// in te bekijken per scherm (normaal tussen 0 en 1023 in theorie)
boolean P_ON = false;
// Making TFT object
//used pins (int CS=A3, int RS=A2, int WR=A1, int RD=A0, int RST=A4)
MCUFRIEND_kbv tft(A3, A2, A1, A0, A4);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300); // activeren touchmogelijkheid
Adafruit_GFX_Button on_Btn, off_Btn;
void OnOff(){
tft.clear;
if (P_ON == false) {
Serial.println ("OK"); delay(1000);
tft.fillRoundRect(10,290,50,20,2, GREEN);
tft.setCursor(18,292);
tft.setTextColor(BLACK);
tft.setTextSize(2);
tft.print("ON");
// on_Btn.initButton(&tft,30, 300, 50, 30, BLACK, GREEN, BLACK, "OFF",2);
// on_Btn.drawButton(false);
Serial.print("LEDS on");
P_ON = true;
else {
tft.fillRoundRect(10,290,50,20,2, RED);
tft.setCursor(17,292);
tft.setTextSize(2);
tft.print("OFF");
P_ON = false;
// on_Btn.initButton(&tft, 30, 300, 50, 30, BLACK, RED, BLACK, "ON", 2); // x, y, w, h, outline, fill, text
Serial.print("LEDs Off");
void setup(){
TSPoint p = ts.getPoint();
uint16_t ID = tft.readID();
tft.begin(ID);
// complementaire kleur if true
tft.invertDisplay(false);
tft.setRotation(0);
tft.width(); //int16_t width(void);
tft.height(); //int16_t height(void);
Serial.println("Hoogte: ");
Serial.println(tft.height());
Serial.println("Breedte: ");
Serial.print(tft.width());
// uint16_t x =160, y =2;
tft.fillScreen(WHITE);
tft.fillRect(30, 2, 182, 22, BLACK);
tft.setCursor(32,4);
tft.setTextColor(WHITE);
tft.setTextSize(2);
tft.print("Programable LED");
tft.fillRect(80, 40, 50,50, RED);
// on_Btn.drawButton(false); werkt niet, je kan de Button niet wijzigen eenmaal initieerd
// dan maar zelf een knop maken:
tft.setTextSize(2);
tft.print("OFF");
// p = ts.getPoint();
// p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
// p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
// Serial.println(p.x);
// Serial.println(p.y);
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
p = ts.getPoint();
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
// scale from 0->1023 to tft.width
if ((p.x > 7 && p.x< 54) and (p.y >289 && p.y < 311)){ // on_Btn.contains(p.x, p.y)) {
Serial.print("Pressing: "); delay(200);
// on_Btn.press(true); // tell the button it is pressed
OnOff();
// else {
// on_Btn.press(false); // tell the button it is NOT pressed
if (on_Btn.justReleased()) {
Serial.print("Released: ");
on_Btn.drawButton(); // draw normal
if (on_Btn.justPressed()) {
on_Btn.drawButton(true); // draw invert!
// Commands();
