TFT Display: conversion of string for printf()
Hi
I am trying to display my string variable (train_id) on a ST7735 TFT Module. I learnt that I need to convert the string to char array first as string is not supported by the TFT Library. I used the code provided in this forum but how can I then display the result on the TFT display using the printf() Function?
Thank you for your help.
Remo
String str = train_id;
// Length (with one extra character for the null terminator)
int str_len = str.length() + 1;
// Prepare the character array (the buffer)
char char_array[str_len];
// Copy it over
(str.toCharArray(char_array, str_len));
tft.printf(? ? ? ?);
Please post your entire sketch using code tags and described here:
Read this before posting a programming question ...
Why is train_id a String in the first place rather than a zero terminated array of chars ?
answer is
tft.printf(char_array);
what is train_id's type? if it's a number, then
tft.printf(train_id);
might just work as the ST7735 library inherits from Adafruit_GFX which supports Print
The chain of inheritance is a little long:
class Adafruit_ST7735 : public Adafruit_ST77xx {
class Adafruit_ST77xx : public Adafruit_SPITFT {
class Adafruit_SPITFT : public Adafruit_GFX
class Adafruit_GFX : public Print {
So, yes, Adafruit_ST7735 ultimately inherits from Print. Print knows how to Print an object of the String class. Therefore, I see no basis for OP's original statement:
patschifig123:
exactly :slight_smile:
Is OP using the Adafruit library?
fair question. Maybe not
