TFT Display not working
Hey guys, I'm a little programmer but I am lazy. I wanted to have a software on the TFT Display so I asked ChatGPT.
I have:
TFT LCD Display ILI9341 | XPT2046
Arduino UNO
The display is just on Top of the Arduino.
I wanted:
A Software for fans so that I have 1 Button called "Auto" and one called "Manual". To protect the buttons there should be a 4 digit password protected menu. The button "Auto" should be without a function at the time. When I press the button "Manual" there should be appear a slider so that I can Control the RPM of the fans.
So for now ChatGPT made me a code. But when I press "Manual" the Serial Monitor prints out that I pressed it but on the TFT Display it just gets white and nothing appears.
Can please someone look at my code and help me? (Just ignore at first the German and the Password protected area)
#include#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
MCUFRIEND_kbv tft;
// Touchscreen Pins für dein Shield
#define YP A3
#define XM A2
#define YM 9
#define XP 8
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define MINPRESSURE 200
#define MAXPRESSURE 1000
// Farbwerte für TFT
#define BLACK   0x0000
#define WHITE   0xFFFF
#define RED     0xF800
#define GREEN   0x07E0
#define BLUE    0x001F
#define GREY    0x7BEF
bool autoMode = false;
int fanSpeed = 50;
    uint16_t ID = tft.readID();
    Serial.print("TFT Display ID: 0x");
    Serial.println(ID, HEX);
    if (ID == 0xFFFF || ID == 0x0000) ID = 0x9341;
    tft.begin(ID);
    tft.setRotation(0);
    Serial.println("Starte Hauptmenü...");
    showMainMenu();
    checkTouch();
// =================== 🏠 HAUPTMENÜ ===================
void showMainMenu() {
    Serial.println("Lösche Bildschirm und zeichne Hauptmenü...");
    tft.fillScreen(BLACK);
    // Titel
    tft.setTextColor(WHITE, BLACK);
    tft.setTextSize(2);
    tft.setCursor(40, 30);
    tft.print("Luefter Steuerung");
    // Auto-Button
    tft.fillRect(20, 100, 100, 50, autoMode ? GREEN : GREY);
    tft.setTextColor(BLACK);
    tft.setCursor(40, 120);
    tft.print("AUTO");
    // Manuell-Button
    tft.fillRect(130, 100, 100, 50, !autoMode ? RED : GREY);
    tft.setCursor(140, 120);
    tft.print("MANUELL");
    Serial.println("Hauptmenü erfolgreich gezeichnet!");
// =================== 🖲 TOUCHSTEUERUNG ===================
void checkTouch() {
    TSPoint p = ts.getPoint();
    if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
        int touchX = map(p.x, 100, 900, 0, 240);
        int touchY = map(p.y, 100, 900, 0, 320);
        Serial.print("Touch erkannt! X = "); Serial.print(touchX);
        Serial.print(" Y = "); Serial.println(touchY);
        // Prüfe "AUTO"-Button
        if (touchX > 20 && touchX < 120 && touchY > 100 && touchY < 150) {
            Serial.println("AUTO-Modus aktiviert!");
            autoMode = true;
            showMainMenu();
        // Prüfe "MANUELL"-Button
        if (touchX > 130 && touchX < 230 && touchY > 100 && touchY < 150) {
            Serial.println("MANUELL-Modus aktiviert!");
            autoMode = false;
            showSlider();
        delay(300);
// =================== 🎛 SCHIEBEREGLER – FINALER TEST ===================
void showSlider() {
    Serial.println("Wechsle zum Schieberegler...");
    // ⚠ WICHTIG: ERZWINGE TFT BEGIN, UM UPDATE ZU SICHERN
    Serial.print("TFT NEU INITIALISIERT MIT ID: 0x");
    tft.begin(ID);
    tft.setRotation(1);
    // Bildschirm löschen
    Serial.println("Zeichne Schieberegler-Hintergrund...");
    // Titel
    tft.setTextSize(2);
    tft.print("Manuelle Steuerung");
    // Zeichne Slider-Hintergrund (weiße Linie)
    tft.fillRect(20, 150, 200, 10, WHITE);
    delay(100);
    Serial.println("Zeichne Schieberegler...");
    drawSlider();
    Serial.println("Schieberegler fertig gezeichnet!");
// ✅ Sicherstellen, dass der Schieberegler korrekt gezeichnet wird
void drawSlider() {
    Serial.print("Zeichne Schieberegler... Aktuelle RPM: ");
    Serial.println(fanSpeed);
    // Lösche alten Schieberegler durch eine schwarze Fläche
    tft.fillRect(20, 140, 200, 20, BLACK);
    delay(50);
    // Zeichne neuen Schieberegler
    int sliderPos = 20 + (fanSpeed * 2);
    tft.fillCircle(sliderPos, 155, 10, RED);
    // Anzeige der RPM-Werte
    tft.fillRect(80, 200, 80, 20, BLACK);
    tft.setCursor(90, 210);
    tft.setTextColor(WHITE);
    tft.setTextSize(2);
    tft.print(fanSpeed);
    tft.print("%");
    Serial.println("Schieberegler aktualisiert!");
 <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define YP A3
#define XM A2
#define YM 9
#define XP 8
#define RED     0xF800
#define BLUE    0x001F
#define GREY    0x7BEF
int fanSpeed = 50;
    tft.begin(ID);
    tft.setRotation(0);
    showMainMenu();
    checkTouch();
    // Titel
    tft.setTextSize(2);
    // Auto-Button
    tft.print("AUTO");
    // Manuell-Button
void checkTouch() {
            autoMode = true;
            showMainMenu();
            autoMode = false;
            showSlider();
        delay(300);
void showSlider() {
    tft.begin(ID);
    tft.setRotation(1);
    // Titel
    tft.setTextSize(2);
    delay(100);
    drawSlider();
void drawSlider() {
    delay(50);
    tft.setTextSize(2);
    tft.print("%");
If an AI wrote your code, why don't you ask it to fix the errors?
I Just did but it won't work. I'm working with AI on it since 6 hours yesterday and today. watched several YouTube videos but I just don't get it.
First, run the examples from the library. And only when the image appears on the screen - start reworking the sketch for your project.
Google there is lot's of TFT keypad examples.
Chat Gpt?
Did you post 2 versions of Chat Gpt code in 1 code block?
