Hello, I am a bit confused with the state of my display right now.
It's a touchscreen shield that works with the mcufriend library, it has a screen resolution of 320x480. So the problem is, everytime I go into a loop to check if the screen is being touched in a certain range of coordinates (any range of coordinates given to it), it works fine. But the moment I send a tft.print() in the if statement, it just goes blank until a tft.reset() is executed. The touch is still responsive when the screen goes blank.
Any help will be appreciated a LOT
Here's ALL of my code:
// the regular Adafruit "TouchScreen.h" library only works on AVRs
// different mcufriend shields have Touchscreen on different pins
// and rotation.
// Run the TouchScreen_Calibr_native sketch for calibration of your shield
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft; // hard-wired for UNO shields anyway.
#include <TouchScreen.h>
char *name = "Fcalc shield"; //edit name of shield
const int XP=6,XM=A2,YP=A1,YM=7; //ID=0x9341
const int TS_LEFT=907,TS_RT=136,TS_TOP=942,TS_BOT=139;
const int XP=8,XM=A2,YP=A3,YM=9; //320x480 ID=0x9486
const int TS_LEFT=123,TS_RT=909,TS_TOP=956,TS_BOT=95;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
TSPoint tp;
// Object with String keys and String values
typedef struct _tuple { const char key; int val; } Tuple;
// ntouch means number keypad touch button coordinates
#define MINPRESSURE 200
#define MAXPRESSURE 1000
uint8_t Orientation = 0; //PORTRAIT
uint16_t ID;
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GRAY 0x7BEF
#define topBarColor 0xCE79
#define topTextColor BLACK
#define topLineColor 0x0000
void show_Serial(void)
Serial.println(F("Most Touch Screens use pins 6, 7, A1, A2"));
Serial.println(F("But they can be in ANY order"));
Serial.println(F("e.g. right to left or bottom to top"));
Serial.println(F("or wrong direction"));
Serial.println(F("Edit name and calibration statements\n"));
Serial.println(name);
Serial.print(F("ID=0x"));
Serial.println(ID, HEX);
Serial.println("Screen is " + String(tft.width()) + "x" + String(tft.height()));
Serial.println("Calibration is: ");
Serial.println("LEFT = " + String(TS_LEFT) + " RT = " + String(TS_RT));
Serial.println("TOP = " + String(TS_TOP) + " BOT = " + String(TS_BOT));
Serial.println("Wiring is always PORTRAIT");
Serial.println("YP=" + String(YP) + " XM=" + String(XM));
Serial.println("YM=" + String(YM) + " XP=" + String(XP));
void show_tft(void)
String msg = "";
tft.fillScreen(WHITE);
tft.setTextColor(BLACK);
tft.setCursor(0, 0);
tft.setTextSize(1);
tft.print(F("ID=0x"));
tft.println(ID, HEX);
tft.println("Current panel: " + String(tft.width()) + "x" + String(tft.height()));
tft.println("");
tft.setTextColor(BLUE);
tft.setTextSize(2);
tft.println("Formula Calculator v0.1");
tft.println("Designed by Kosain");
tft.setTextSize(1);
tft.println("");
tft.println("PORTRAIT Values:");
tft.println("LEFT = " + String(TS_LEFT) + " RT = " + String(TS_RT));
tft.println("TOP = " + String(TS_TOP) + " BOT = " + String(TS_BOT));
tft.println("\nWiring is: ");
tft.println("YP=" + String(YP) + " XM=" + String(XM));
tft.println("YM=" + String(YM) + " XP=" + String(XP));
tft.setTextSize(2);
tft.setTextColor(0x0320);
tft.setCursor((tft.width() - 65) / 2, (tft.height() * 2) / 4);
tft.print("Run >_");
tft.drawRect(110, 220, 105, 55, 0x0320);
tft.setTextColor(BLACK, WHITE);
tft.setCursor(0, (tft.height() * 6) / 8);
tft.println("Touch screen for");
tft.print("pos and depth");
while (1) {
tp = ts.getPoint();
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
if (tp.z < MINPRESSURE || tp.z > MAXPRESSURE) continue;
if (tp.x > 402 && tp.x < 645 && tp.y > 480 && tp.y < 565) break;
tft.setCursor(0, (tft.height() * 3) / 4);
tft.println("tp.x=" + String(tp.x) + " tp.y=" + String(tp.y));
if (tp.z < 540) {
tft.setTextColor(MAGENTA, WHITE);
msg = "Push lightly ";
if (tp.z < 500) {
tft.setTextColor(RED, WHITE);
msg = "Don't push too hard!! ";
if (tp.z < 400) {
msg = "Don't use fingers! ";
if (tp.z < 300) {
msg = "Multitouch isn't supported...";
if (tp.z > 540) {
msg = " ";
tft.println("tp.z=" + String(tp.z) + " ");
tft.println(msg);
void setup(void)
uint16_t tmp;
tft.reset();
ID = tft.readID();
tft.begin(ID);
show_Serial();
tft.setRotation(Orientation);
tft.fillScreen(BLACK);
show_tft();
// BOXSIZE = tft.width() / 6;
tft.fillRect(0, 0, tft.width(), 30, BLACK);
tft.drawLine(0, 30, tft.width(), 30, WHITE);
uint16_t xpos, ypos; //screen coordinates
void touchPos(){
// uint16_t xpos, ypos; //screen coordinates
tp = ts.getPoint(); //tp.x, tp.y are ADC values
switch (Orientation) {
case 0:
xpos = map(tp.x, TS_LEFT, TS_RT, 0, tft.width());
ypos = map(tp.y, TS_TOP, TS_BOT, 0, tft.height());
case 1:
xpos = map(tp.y, TS_TOP, TS_BOT, 0, tft.width());
ypos = map(tp.x, TS_RT, TS_LEFT, 0, tft.height());
case 2:
xpos = map(tp.x, TS_RT, TS_LEFT, 0, tft.width());
ypos = map(tp.y, TS_BOT, TS_TOP, 0, tft.height());
case 3:
xpos = map(tp.y, TS_BOT, TS_TOP, 0, tft.width());
ypos = map(tp.x, TS_LEFT, TS_RT, 0, tft.height());
void screenBtn(String type){
if (type == "back"){
tft.setCursor(283, 47);
tft.fillRect(280, 40, 30, 30, 0x2800);
tft.drawRect(279, 39, 31, 31, RED);
tft.drawRect(280, 40, 30, 31, RED);
tft.setTextColor(WHITE);
tft.print("<-");
if (type == "close"){
tft.setCursor(290, 47);
tft.print("X");
int x1, x2, y1, y2;
bool screenBtnTouch(String type, bool debugPrintValues){
tp = ts.getPoint();
if (type == "back")
// int x1, x2, y1, y2;
x1 = 820;
x2 = 870;
y1 = 838;
y2 = 888;
if (debugPrintValues == true)
Serial.println(String(tp.x) + " " + String(tp.y));
Serial.println("pressure: " + String(tp.z));
return (tp.x > x1 && tp.x < x2 && tp.y > y1 && tp.y < y2);
void loadScreen(String scr, bool resetTft){
if (resetTft)
tft.begin(ID);
tft.fillRect(0, 0, tft.width(), 30, topBarColor);
tft.drawLine(0, 30, tft.width(), 30, topLineColor);
tft.setTextSize(2);
tft.setCursor(5, 5);
tft.setTextColor(topTextColor);
tft.print("Waiting for GUI Refresh...");
// tft.fillRect(0, 31, tft.width(), tft.height(), 0xF7BE);
tft.fillRect(0, 31, tft.width(), tft.height(), WHITE);
if (scr == "home")
tft.print("Fcalc v0.1");
tft.setTextSize(3);
tft.setCursor(15, 50);
tft.println("Formulas:");
tft.setTextSize(2);
int homeBtnY = 102;
int homeBtnXlen = 215;
tft.setCursor(22, homeBtnY);
tft.fillRect(15, homeBtnY - 8, homeBtnXlen, 30, BLACK);
tft.setCursor(28, homeBtnY - 5);
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0x075F);
tft.print("Quadratic (Poly2)");
homeBtnY += 50;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0x07F0);
tft.print("Term (Tn/Un)");
homeBtnY += 50;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0x2FE0);
tft.print("Sum of n (Sn)");
if (scr == "formulaQuad")
tft.setTextColor(0x03B0);
tft.print(" -> Quadratic");
tft.setTextSize(3);
tft.println("Quadratic");
tft.setTextSize(2);
tft.setCursor(15, 75);
tft.println("ax^2 + bx + c = 0");
int homeBtnY = 120;
int homeBtnXlen = 40;
int yTBoxA, yTBoxB, yTBoxC;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0xFCB2);
tft.print("a=");
tft.setCursor(80, homeBtnY - 5);
yTBoxA = homeBtnY - 5;
tft.print("?");
homeBtnY += 50;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0x97F2);
tft.print("b=");
yTBoxB = homeBtnY - 5;
tft.print("?");
homeBtnY += 50;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0x94BF);
tft.print("c=");
yTBoxC = homeBtnY - 5;
tft.print("?");
screenBtn("back");
if (scr == "formulaAPTerm")
tft.setTextColor(0x0408);
tft.print(" -> AP Tn");
tft.setTextSize(3);
tft.println("Term Number");
tft.setTextSize(2);
tft.println("Tn = a + (n-1)d");
int homeBtnY = 120;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0xFB2C);
tft.print("a=");
tft.print("?");
homeBtnY += 50;
tft.fillRect(20, homeBtnY - 12, homeBtnXlen, 30, 0xFFEC);
tft.print("d=");
tft.print("?");
homeBtnY += 50;
tft.print("n=");
tft.print("?");
screenBtn("back");
int screenKeypad(bool show, String title)
// action: bring up keypad
int colorBg, colorTopLine, colorText, colorTitle;
colorBg = 0xE73C;
colorTopLine = BLACK;
colorText = BLACK;
colorTitle = BLUE;
if (show == true)
tft.fillRect(0, 300, tft.width(), tft.height() - 300, colorBg);
tft.drawLine(0, 300, tft.width(), 300, colorTopLine);
tft.setCursor(5, 326);
tft.setTextColor(colorText);
tft.println(title);
tft.drawRect(5, 305, tft.width() - 10, 17, BLACK);
tft.fillRect(6, 306, tft.width() - 12, 15, WHITE);
tft.fillRect(tft.width() - 20 - 5, tft.height() - 20 - 5, 20, 20, RED); // make keypad close button
// keypad buttons:
tft.setTextSize(2);
tft.drawRect(9, 351, 30, 30, BLACK);
tft.fillRect(10, 350, 30, 30, WHITE);
tft.setCursor(18, 355);
tft.print("1");
// ntouch means numerical keypad button touch coordinates. Coordinates stored in dictionary
// touch colliders set in a list:
dict ntouch[] = {
{"onex1", 153},
{"onex2", 217},
{"oney1", 276},
{"oney2", 322}
int onex1, onex2, oney1, oney2;
onex1 = 153;
onex2 = 217;
oney1 = 276;
oney2 = 322;
ntouch["onex1"] = 153;
ntouch["onex2"] = 217;
ntouch["oney1"] = 276;
ntouch["oney2"] = 322;
while(1)
tp = ts.getPoint();
tft.setCursor(8, 308);
x1 = ntouch["onex1"];
x2 = ntouch["onex2"];
y1 = ntouch["oney1"];
y2 = ntouch["oney2"];
x1 = 857;
x2 = 885;
y1 = 113;
y2 = 137;
if (tp.x > x1 && tp.x < x2 && tp.y > y1 && tp.y < y2)
loadScreen("formulaQuad", true);
Serial.println("Closed");
return NULL;
// keypad button touch logic:
if (tp.x > onex1 && tp.x < onex2 && tp.y > oney1 && tp.y < oney2)
tft.setTextSize(1);
tft.print("1");
Serial.println("One pressed");
while(tp.z > 10) //{tp = ts.getPoint();} // wait until user lets go of button
tp = ts.getPoint();
tft.print("hi"); // <- Over here
// the printing of hi is a test here, it goes blank the moment it executes it
Serial.println("One released");
if (show == false)
tft.fillRect(0, 300, tft.width(), tft.height() - 300, WHITE);
// if sharing pins, you'll need to fix the directions of the touchscreen pins
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
int x1, x2, y1, y2;
String screen;
while(1)
loadScreen("home", true); // formula selection screen
tp = ts.getPoint();
String formulaButtonList[] =
"formulaQuad",
"formulaAPTerm",
"formulaAPSum"
while (1) { // logic loop for selecting formula or next screen
tp = ts.getPoint();
// Serial.println(String(tp.x) + " " + String(tp.y));
if (tp.x > 183 && tp.x < 694 && tp.y > 750 && tp.y < 794)
screen = formulaButtonList[0];
if (tp.x > 183 && tp.x < 694 && tp.y > 656 && tp.y < 705)
screen = formulaButtonList[1];
if (tp.x > 183 && tp.x < 694 && tp.y > 576 && tp.y < 619)
screen = formulaButtonList[2];
//break;
// load corresponding screen:
loadScreen(screen, false);
tft.setTextSize(2);
while(1) // logic for handling the interactivity of the screen:
// back button logic:
tp = ts.getPoint();
if (screenBtnTouch("back", false) == true)
screen = "home";
// quadratic formula interactivity:
if (screen == "formulaQuad")
tft.setTextSize(2);
int a, b, c;
x1 = 186;
x2 = 258;
y1 = 720;
y2 = 764;
int a = screenKeypad(true, "Enter value for (a).");
tft.setTextSize(2);
Thanks in advance.
