TFT display with temperature reading not working
Hi, I have a problem with my code, I hope somebody is willing to help.
I have my TFT display and a button to open and close a servo motor. But once I add the lines with readings from DHT temperature and humid. sensor, the button doesn't work anymore.
I will attach the code below. thank you
/// TFT TOCUH SCREEEN DISPLAY
#include <TouchScreen.h> //touch library
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
//const char temper = "Temperatura si umiditate";
LCDWIKI_KBV my_lcd(ILI9486, A3, A2, A1, A0, A4); //model,cs,cd,wr,rd,reset
#define BLACK        0x0000  /*   0,   0,   0 */
#define BLUE         0x001F  /*   0,   0, 255 */
#define RED          0xF800  /* 255,   0,   0 */
#define GREEN        0x07E0  /*   0, 255,   0 */
#define CYAN         0x07FF  /*   0, 255, 255 */
#define MAGENTA      0xF81F  /* 255,   0, 255 */
#define YELLOW       0xFFE0  /* 255, 255,   0 */
#define WHITE        0xFFFF  /* 255, 255, 255 */
#define NAVY         0x000F  /*   0,   0, 128 */
#define DARKGREEN    0x03E0  /*   0, 128,   0 */
#define DARKCYAN     0x03EF  /*   0, 128, 128 */
#define MAROON       0x7800  /* 128,   0,   0 */
#define PURPLE       0x780F  /* 128,   0, 128 */
#define OLIVE        0x7BE0  /* 128, 128,   0 */
#define LIGHTGREY    0xC618  /* 192, 192, 192 */
#define DARKGREY     0x7BEF  /* 128, 128, 128 */
#define ORANGE       0xFD20  /* 255, 165,   0 */
#define GREENYELLOW  0xAFE5  /* 173, 255,  47 */
#define PINK         0xF81F  /* 255,   0, 255 */
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
//touch sensitivity for X
#define TS_MINX     871  //  906
#define TS_MAXX    124   //    116
//touch sensitivity for Y
#define TS_MINY        207  //  92
#define TS_MAXY       842  //  952
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
boolean is_pressed(int16_t x1,int16_t y1,int16_t x2,int16_t y2,int16_t px,int16_t py)
    if((px > x1 && px < x2) && (py > y1 && py < y2))
        return true;
        return false;
boolean switch_flag_1 = true,switch_flag_2 = true;
void show_string(uint8_t *str, int16_t x, int16_t y, uint8_t csize, uint16_t fc, uint16_t bc, boolean mode)
  my_lcd.Set_Text_Mode(mode);
  my_lcd.Set_Text_Size(csize);
  my_lcd.Set_Text_colour(fc);
  my_lcd.Set_Text_Back_colour(bc);
  my_lcd.Print_String(str, x, y);
//// 8X8 Control
#include "LedControl.h"
#include "binary.h"
LedControl lc = LedControl(48, 47, 49, 1);
byte af[8] = {0x3c, 0x42, 0xa1, 0x87, 0x8f, 0xfb, 0x7e, 0x3c};
byte ad[8] = {0x81, 0x42, 0x24, 0x18, 0x18, 0x24, 0x42, 0x81};
//////////////// senzor temp
#include <dht.h>
dht DHT;
#define DHT11_PIN 52
const int buttonPin = 53;
unsigned long delaytime = 100;
////////////////// KEYPAD + PASSWORD + SERVO
#include <Keypad.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int closeServo = 1; // Adjust the fine movement
int openServo = 90; // Adjust the fine movement
int buttoncheck; // initializeaza verificare buton
//keypad
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the two-dimensional array on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {38, 39, 40, 41}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {42, 43, 44, 45}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
// PASSWORD MANAGER
const char* password = "32"; // change the password here, just pick any numbers/letters
int lengthpwd = 2; // change the length of the password
int carriage = 0;
int attempt = 0;
// LED and sound
//unsigned int redLed = 45;
unsigned int greenLed = 46;
unsigned int piezo = 50;
unsigned int note = 300;
// Millis
unsigned long currentMillis;
unsigned long previousMillis; // will store last time LED was updated
unsigned long previousMillis2;
int ledState = LOW; // ledState used to set the LED
// constants won't change:
const long interval = 800;
const long Tinterval = 2000;  //constanta millis Tinterval pt DHT/senzor temperatura-umiditate
int prevTempLevel = 0;
  ////////////////////////////DISPLAY
  my_lcd.Init_LCD();
  my_lcd.Fill_Screen(OLIVE);
// linii
my_lcd.Draw_Line(15, 40, 305, 40);
 my_lcd.Set_Draw_color(BLACK);
 show_string("TEMPERATURA SI UMIDITATE", 15, 13, 2, BLUE, 1, WHITE);
//butoane
  my_lcd.Fill_Round_Rectangle(158, 358, 282, 462, 3);
  my_lcd.Set_Draw_color(RED);
  my_lcd.Fill_Round_Rectangle(160, 360, 280, 460, 3);
  //////////////////////////////8X8 matrix
  lc.shutdown(0, false);
  // Set brightness to a medium value
  lc.setIntensity(0, 4);
  // Clear the display
  lc.clearDisplay(0);
  //buttonnnn
  buttoncheck = 0;
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT_PULLUP);
  // keypadddd
  myservo.attach(51); // attaches the servo on pin 10 to the servo object
  myservo.write(closeServo);
  //  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  //digitalWrite(redLed, 1);
  tone(piezo, note, 20);
  // digitalWrite(greenLed, 1);
  digitalWrite(greenLed, 0);
  //  digitalWrite(redLed, 0);
//////////8x8 LED DRAW
void drawFaces() {
  lc.setRow(0, 0, af[0]);
  lc.setRow(0, 1, af[1]);
  lc.setRow(0, 2, af[2]);
  lc.setRow(0, 3, af[3]);
  lc.setRow(0, 4, af[4]);
  lc.setRow(0, 5, af[5]);
  lc.setRow(0, 6, af[6]);
  lc.setRow(0, 7, af[7]);
void drawFaces2() {
  lc.setRow(0, 0, ad[0]);
  lc.setRow(0, 1, ad[1]);
  lc.setRow(0, 2, ad[2]);
  lc.setRow(0, 3, ad[3]);
  lc.setRow(0, 4, ad[4]);
  lc.setRow(0, 5, ad[5]);
  lc.setRow(0, 6, ad[6]);
  lc.setRow(0, 7, ad[7]);
//////////////////////////////////////////////////////////////////////////DISPLAY
digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE)
    //p.x = my_lcd.Get_Display_Width()-map(p.x, TS_MINX, TS_MAXX, my_lcd.Get_Display_Width(), 0);
    //p.y = my_lcd.Get_Display_Height()-map(p.y, TS_MINY, TS_MAXY, my_lcd.Get_Display_Height(), 0);
    p.x = map(p.x, TS_MINX, TS_MAXX, my_lcd.Get_Display_Width(),0);
    p.y = map(p.y, TS_MINY, TS_MAXY, my_lcd.Get_Display_Height(),0);
    if(is_pressed(160, 400, 280, 480,p.x,p.y))
      if(switch_flag_1)
        {   //display off
             myservo.write(openServo);
     tone(piezo, 200, 100);
    delay(80);
    tone(piezo, 200, 50);
    delay(80);
    tone(piezo, 100, 50);
    delay(80);
    tone(piezo, 70, 50);
    delay(100);
    // digitalWrite(redLed, 1);
    my_lcd.Set_Draw_color(GREEN);
  drawFaces();
            switch_flag_1 = false;
         {  //display on
    delay(80);
    delay(80);
    delay(80);
    delay(100);
  drawFaces2();
           switch_flag_1 = true;
/////////////       keypad
  char key = customKeypad.getKey();
  if (key) {
    Serial.println("");
    Serial.println("______________");
    Serial.print("Button pressed: ");
    Serial.println(key);
    Serial.print("Carriage: ");
    Serial.println(carriage);
    Serial.print("Attempt: ");
    Serial.println(attempt);
    Serial.println("_____________");
    attempt++;
  if (key == '*' || key == '#')
    carriage = 0;
    attempt = 0;
    Serial.println("Clear");
    tone(piezo, 800, 300);
    delay(80);
    tone(piezo, 800, 100);
    delay(80);
    tone(piezo, 700, 100);
    delay(80);
    tone(piezo, 600, 100);
    delay(100);
    delay(200);
    drawFaces2();
  if (key == password[carriage])
    carriage ++;
    Serial.println("--> Right!");
  if (carriage == lengthpwd)
    Serial.println("--> Bingo! <--");
    carriage = 0;
    attempt = 0;
    delay(50);
    delay(50);
    delay(60);
    delay(80);
    for (int i = 0; i < 6; i++) {
      delay(200);
      delay(100);
    drawFaces();
  if (attempt >= lengthpwd) {
    Serial.println("--> Not the right code! <--");
    tone(piezo, 450, 100);
    delay(100);
    tone(piezo, 400, 200);
    carriage = 0;
    attempt = 0;
  if (carriage > lengthpwd)
    Serial.println("Superior");
    carriage = 0;
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    //   digitalWrite(redLed, ledState);
  //butonnn
  if (digitalRead(53) == HIGH) {
    buttoncheck = 1;
    delay(80);
    delay(80);
    delay(80);
    delay(100);
    delay(200);
    drawFaces2();
  if (digitalRead(53) == HIGH && buttoncheck == 1) {
    buttoncheck = 0;
    buttoncheck = 1;
    delay(80);
    delay(80);
    delay(80);
      delay(200);
      delay(100);
    drawFaces();
 /// TEMPERATURA
  int t = DHT.temperature;
  if ((t <= 100 ) && (t >= 0 )) {
    int T_bar = map(t, 0, 50, 0, 80);
    if ((prevTempLevel - T_bar) != 0) {
  //  my_lcd.Set_Draw_color(ORANGE);
   //   my_lcd.Fill_Rectangle(70, 150  , 100 ,  300 - T_bar );
    prevTempLevel = T_bar;
//loop pt DHT senzor temperatura-umiditate
  if (currentMillis - previousMillis2 >= Tinterval) {
    previousMillis2 = currentMillis;
    int chk = DHT.read11(DHT11_PIN);
  // Serial.print("Temperatura = ""°");
    //Serial.println(DHT.temperature);
  //  Serial.print("Umiditate = ""%");
    //Serial.println(DHT.humidity);
  } // temperatura si umiditate display
   show_string("C", 245, 260, 3, ORANGE, OLIVE, 0);
   my_lcd.Set_Text_Mode(0);
  my_lcd.Set_Text_Back_colour(OLIVE);
  my_lcd.Print_Number_Float(DHT.temperature, 1, 160, 260, '.', 3, ' ');
 show_string("%", 245, 300, 3, CYAN, OLIVE, 0);
  my_lcd.Print_Number_Float(DHT.humidity, 1, 160, 300, '.', 3, ' ');
