TFT Displaying Live Values
Working on a project where i need to display live sensor values on a 3.5in TFT Touchscreen LCD. The current method im using does the job, but if you blink you'll missing the displayed value. On top of that theres a long period of no displayed value on the screen. It simply makes a blacked out rectangle over the old value and the new value prints over the rectangle. Is there a way i can have an easy to read value displayed without it flickering?
Heres the current code im using:
// INCLUDE
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <pin_magic.h>
#include <registers.h>
#include <TouchScreen.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <Wire.h>
//DEFINE
#if defined(SAM3X8E)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
#define YP A2 // must be an analog pin, use "An" notation!
#define XM A3 // must be an analog pin, use "An" notation!
#define YM 8 // can be a digital pin
#define XP 9 // can be a digital pin
#define TS_MINX 130
#define TS_MAXX 905
#define TS_MINY 75
#define TS_MAXY 930
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define MINPRESSURE 5
#define MAXPRESSURE 1000
#define PENRADIUS 2
//INT
int speed1;
int change;
int percentage;
int lsdtreading;
int in1 = 22;
int in2 = 24;
int ENA = 13;
int distance;
int length1 = 76.2; //3 in = 76.2 mm
//OTHER
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
String inString = ""; // string to hold input
void Motor_Setup() {
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(ENA, OUTPUT);
digitalWrite(24, LOW);
digitalWrite(22, HIGH);
void mainUI() {
tft.setRotation(1);
tft.fillScreen(BLACK);
//HEADER
//tft.setRotation(3);
tft.setCursor(25, 20);
tft.setTextSize(3);
tft.println("3451L FLYBALL TACHOMETER");
tft.fillRect(15, 60, 450, 2, RED);
tft.fillRect(15, 95, 450, 2, RED);
tft.fillRect(15, 130, 450, 2, RED);
tft.fillRect(15, 165, 450, 2, RED);
tft.fillRect(15, 200, 450, 2, RED);
tft.fillRect(15, 235, 450, 2, RED);
tft.fillRect(15, 270, 450, 2, RED);
tft.fillRect(15, 305, 450, 2, RED);
tft.fillRect(15, 60, 2, 247, RED);
tft.fillRect(245, 60, 2, 247, RED);
tft.fillRect(465, 60, 2, 247, RED);
tft.setTextSize(3);
tft.setCursor(25, 70);
tft.println("Motor Output");
tft.setCursor(25, 105);
tft.println("Motor (R)");
tft.setCursor(25, 140);
tft.println("Shaft (R)");
tft.setCursor(25, 175);
tft.println("Height (E)");
tft.setCursor(25, 210);
tft.println("Angle (E)");
tft.setCursor(25, 245);
tft.println("Shaft (E)");
tft.setCursor(25, 280);
tft.println("Error");
tft.setCursor(441, 70);
tft.println("%");
tft.setCursor(405, 105);
tft.println("RPM");
tft.setCursor(405, 140);
tft.println("RPM");
tft.setCursor(422, 175);
tft.println("mm");
tft.setCursor(405, 210);
tft.println("deg");
tft.setCursor(405, 245);
tft.println("RPM");
tft.setCursor(441, 280);
tft.println("%");
Serial1.begin(9600);
Serial2.begin(9600);
while (!Serial); // wait for
tft.reset();
tft.begin(0x9486);
Motor_Setup();
mainUI();
void MotorA() {
speed1 = map(analogRead(A15), 1024, 0, 0, 255);
speed1 = 1024 - analogRead(A15);
speed1 = speed1 * 0.2492668622;
analogWrite(ENA, speed1);
//Serial.println(speed1);
//Motor Display
tft.setTextSize(3);
percentage = (speed1 * 100) / 255;
//Serial.println(percentage);
if (percentage < 10) {
tft.setCursor(370, 70);
tft.println(percentage);
else if (percentage < 100) {
tft.setCursor(355, 70);
else {
tft.setCursor(335, 70);
void RPM() {
char myRPM[5];
while (Serial1.available() > 0) {
byte m = Serial1.readBytesUntil('\n', myRPM, 5);
myRPM[m] = '\0';
float rpm = atof(myRPM);
float rpm2 = rpm * 0.6;
Serial.println(rpm, 2);
tft.setTextSize(3);
if (rpm > 300) {
//Motor Display
tft.setCursor(300, 105);
tft.println(rpm, 0);
//Shaft Display
tft.setCursor(300, 140);
tft.println(rpm2, 0);
delay(50);
void Height() {
char distance1[5];
while (Serial2.available() > 0) {
byte m = Serial2.readBytesUntil('\n', distance1, 5);
distance1[m] = '\0';
int height0 = atoi(distance1)-35;
//float height1 = height0 * 0.0393701 - 0.9;//Inches
Serial.println(height0);
tft.setTextSize(3);
//Height Display
tft.setCursor(320, 175);
tft.println(height0);
//Angle Display
int angle = acos(height0 / (2 * length1));
tft.setCursor(340, 210);
tft.println(angle);
//Vertical Velocity
//Experimental RPM
//E.RPM = (v.VELOCITY) / (-2 * lenght1 * sin(acos(distance / (2 * length1))));
void refresh() {
delay(1);
tft.fillRect(247, 62, 155, 32, BLACK);
tft.fillRect(247, 97, 155, 32, BLACK);
tft.fillRect(247, 132, 155, 32, BLACK);
tft.fillRect(247, 167, 175, 32, BLACK);
tft.fillRect(247, 202, 155, 32, BLACK);
tft.fillRect(247, 237, 155, 32, BLACK);
tft.fillRect(247, 272, 155, 32, BLACK);
MotorA();
RPM();
Height();
delay(100);
refresh();
OK, first things first.
You need to go and read the forum instructions so that you can go back and modify your original post (not re-post it) - using the "More -> Modify" option below the right hand corner of your post - to mark up your code as such using the "</>" icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE has a "copy for forum" link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don't forget to use the "Auto-Format" (Ctrl-T) option first to make it easy to read. If you do not post it as "code" it can easily be quite garbled and is always more difficult to read due to the font.
It is inappropriate to attach it as a ".ino" file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And even that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only single blanks between complete functional blocks.
