Hi all.
The TFT_eSPI example Slider_demo sketch works but questions:
touched the Vertical Slider bar, moving happened on Horizontal Slider bar and vice versa;
I have tried changed thetft.setRotation(0);
from 0 to /1/2/3, all other set work slow or no moving; -
I didn't find which line made the moving as below;
if (millis() - scanTime >= 20) {
// Pressed will be set true if there is a valid touch on the screen
if( tft.getTouch(&t_x, &t_y, 250) ) {
if (s1.checkTouch(t_x, t_y)) {
Serial.print("Slider 1 = "); Serial.println(s1.getSliderPosition());
if (s2.checkTouch(t_x, t_y)) {
Serial.print("Slider 2 = "); Serial.println(s2.getSliderPosition());
scanTime = millis();
code:
#include "FS.h"
#include "Free_Fonts.h" // Include the header file attached to this sketch
#include <TFT_eSPI.h>
#include <TFT_eWidget.h> // Widget library
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite knob = TFT_eSprite(&tft); // Sprite for the slide knob
#define CALIBRATION_FILE "/TouchCalData1"
#define REPEAT_CAL false
SliderWidget s1 = SliderWidget(&tft, &knob); // Slider 1 widget
SliderWidget s2 = SliderWidget(&tft, &knob); // Slider 2 widget
tft.begin();
tft.setRotation(0);
tft.fillScreen(TFT_BLACK);
tft.setFreeFont(FF18);
// Calibrate the touch screen and retrieve the scaling factors
if (REPEAT_CAL) {
touch_calibrate();
// Create a parameter set for the slider
slider_t param;
// Slider slot parameters
param.slotWidth = 9; // Note: ends of slot will be rounded and anti-aliased
param.slotLength = 200; // Length includes rounded ends
param.slotColor = TFT_BLUE; // Slot colour
param.slotBgColor = TFT_BLACK; // Slot background colour for anti-aliasing
param.orientation = H_SLIDER; // sets it "true" for horizontal
// Slider control knob parameters (smooth rounded rectangle)
param.knobWidth = 15; // Always along x axis
param.knobHeight = 25; // Always along y axis
param.knobRadius = 5; // Corner radius
param.knobColor = TFT_WHITE; // Anti-aliased with slot backgound colour
param.knobLineColor = TFT_RED; // Colour of marker line (set to same as knobColor for no line)
// Slider range and movement speed
param.sliderLT = 0; // Left side for horizontal, top for vertical slider
param.sliderRB = 100; // Right side for horizontal, bottom for vertical slider
param.startPosition = 50; // Start position for control knob
param.sliderDelay = 0; // Microseconds per pixel movement delay (0 = no delay)
// Create slider using parameters and plot at 0,0
s1.drawSlider(0, 0, param);
// Show bounding box (1 pixel outside slider working area)
int16_t x, y; // x and y can be negative
uint16_t w, h; // Width and height
s1.getBoundingRect(&x, &y, &w, &h); // Update x,y,w,h with bounding box
tft.drawRect(x, y, w, h, TFT_DARKGREY); // Draw rectangle outline
// Alternative discrete fns to create/modify same slider - but fn sequence is important...
s1.createSlider(9, 200, TFT_BLUE, TFT_BLACK, H_SLIDER);
s1.createKnob(15, 25, 5, TFT_WHITE, TFT_RED);
s1.setSliderScale(0, 100);
s1.drawSlider(0, 0);
s1.setSliderPosition(50);
s1.setSliderPosition(100);
// Update any parameters that are different for slider 2
param.slotWidth = 4;
param.orientation = V_SLIDER; // sets it "false" for vertical
param.knobWidth = 19;
param.knobHeight = 19;
param.knobRadius = 19/2; // Half w and h so creates a circle
param.sliderLT = 200; // Top for vertical slider
param.sliderRB = 0; // Bottom for vertical slider
param.sliderDelay = 2000; // 2ms per pixel movement delay (movement is blocking until complete)
s2.drawSlider(0, 50, param);
s2.getBoundingRect(&x, &y, &w, &h);
s2.createSlider(4, 200, TFT_BLUE, TFT_BLACK, V_SLIDER);
s2.createKnob(19, 19, 9, TFT_WHITE, TFT_RED);
s2.setSliderScale(200, 0, 2000);
s2.drawSlider(0, 50);
// Move slider under software control
s2.setSliderPosition(50);
s2.setSliderPosition(100);
static uint32_t scanTime = millis();
uint16_t t_x = 9999, t_y = 9999; // To store the touch coordinates
// Scan for touch every 50ms
//s1.moveTo(random(101));
//delay(250);
//s2.moveTo(random(101));
//delay(250);
void touch_calibrate()
uint16_t calData[5];
uint8_t calDataOK = 0;
// check file system exists
if (!LittleFS.begin()) {
Serial.println("Formating file system");
LittleFS.format();
LittleFS.begin();
// check if calibration file exists and size is correct
if (LittleFS.exists(CALIBRATION_FILE)) {
if (REPEAT_CAL)
// Delete if we want to re-calibrate
LittleFS.remove(CALIBRATION_FILE);
File f = LittleFS.open(CALIBRATION_FILE, "r");
if (f) {
if (f.readBytes((char *)calData, 14) == 14)
calDataOK = 1;
f.close();
if (calDataOK && !REPEAT_CAL) {
// calibration data valid
tft.setTouch(calData);
// data not valid so recalibrate
tft.setCursor(20, 0);
tft.setTextFont(2);
tft.setTextSize(1);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.println("Touch corners as indicated");
tft.setTextFont(1);
tft.println();
if (REPEAT_CAL) {
tft.setTextColor(TFT_RED, TFT_BLACK);
tft.println("Set REPEAT_CAL to false to stop this running again!");
tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
tft.setTextColor(TFT_GREEN, TFT_BLACK);
tft.println("Calibration complete!");
// store data
File f = LittleFS.open(CALIBRATION_FILE, "w");
if (f) {
f.write((const unsigned char *)calData, 14);
f.close();
Thanks.
Adam
