But when I start a new sketch with only Blink in the Led pulse on_off.
pinMode(PC13, OUTPUT);
digitalWrite(PC13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(PC13, LOW); // turn the LED off by making the voltage LOW
CS - A1
DC - A0
RST - A2
MOSI - A7 Connected to TFT.But dont know were it is defined.
CLK - A5 Conected to TFT.But dont know were it is defined.
Even if PC13 is used in the library the led must switch off in the Setup and stay off for 2Secs if the Led comes back on I will know that PC13 is used in the library.
This is then a incorrect defining of my pins as I said I could not find MOSI and SCK in the Library user Setup files.
This is what I done so far , but still no working ILI9163. I do not use CS this pin is hard wired on the display ..works 100% with a Nano.
In User_select_setup.h..line 26
// Only ONE line below should be uncommented. Add extra lines and files as needed.
#include <User_Setup.h> // Default setup is root library folder
//#include <User_Setups/Setup1_ILI9341.h> // Setup file configured for my ILI9341
//#include <User_Setups/Setup2_ST7735.h> // Setup file configured for my ST7735
**#include <User_Setups/Setup3_ILI9163.h>** // Setup file configured for my ILI9163
//#include <User_Setups/Setup4_S6D02A1.h> // Setup file configured for my S6D02A1
//#include <User_Setups/Setup5_RPi_ILI9486.h> // Setup file configured for my stock RPi TFT
//#include <User_Setups/Setup6_RPi_Wr_ILI9486.h> // Setup file configured for my modified RPi TFT
//#include <User_Setups/Setup7_ST7735_128x128.h> // Setup file configured for my ST7735 128x128 display
//#include <User_Setups/Setup8_ILI9163_128x128.h> // Setup file configured for my ILI9163 128x128 display
In User_setup.h..line 42
// Only define one driver, the other ones must be commented out
//#define ILI9341_DRIVER // Generic driver for common displays
//#define ILI9341_2_DRIVER // Alternative ILI9341 driver, see https://github.com/Bodmer/TFT_eSPI/issues/1172
//#define ST7735_DRIVER // Define additional parameters below for this display
**#define ILI9163_DRIVER** // Define additional parameters below for this display
//#define S6D02A1_DRIVER
//#define RPI_ILI9486_DRIVER // 20MHz maximum SPI
//#define HX8357D_DRIVER
In Setup3_ILI9163 ..line 10
// For NodeMCU - use pin numbers in the form PIN_Dx where Dx is the NodeMCU pin designation
//#define TFT_CS PIN_D8 // Chip select control pin D8
**#define TFT_DC PA0** // Data Command control pin
**#define TFT_RST PA1** // Reset pin (could connect to NodeMCU RST, see next line)
//#define TFT_RST -1 // Set TFT_RST to -1 if the display RESET is connected to NodeMCU RST or 3.3V
In User_setup.h..line 257
// ###### EDIT THE PINs BELOW TO SUIT YOUR STM32 SPI TFT SETUP ######
// The TFT can be connected to SPI port 1 or 2
#define TFT_SPI_PORT 1 // SPI port 1 maximum clock rate is 55MHz
#define TFT_MOSI PA7
#define TFT_MISO PA6
#define TFT_SCLK PA5
I have lost the plot somewhere. I strongly advise you to post the whole Setup file. Either by editing Setup32 or by copy-pasting an edited Setup32 to a new custom_Setup file.
Please post a link to the actual ILI9163 display that you have bought.
I possess a BluePill and have two ILI9163 displays. But both have CS.
