hello
i am using tft 2.4 screen to display data from gps
if i just send data to tft.print() it does not clear the previous print
so i use tft.fillScreen but it is slow and disturbs the eye
any hint ?
thanks
Please post a link to your actual screen.
Please quote which TFT library you are using e.g. as reported from Library Manager.
Just guessing that you are using an "Adafruit_GFX" style of library:
Use tft.setTextColor(foreground_color, background_color); to print text in rubout mode.
If you are using the new FreeFonts, the GFX library always use transparent mode.
So you must rubout the previous text with a tft.fillRect(backgound_color);
Calculate the minimum size of rectangle for "rubbing out". The GFX docs explain how to do this.
David.
Thanks David i'll try
and see
Thanks David it worked very well
fidamon
