TFT Help
I needed helped on how to write a code and connect a LCD TFT display to a arduino so that when the LCD display turns on and loads image, it turns off after five seconds. The reason for this is to save battery because the LCD remains on. Please help thanks!
This is my code:
#include <ST7735.h>
#include <SD.h>
#include <SPI.h>
#define sclk 13
#define mosi 11
#define rst 8
#define cs 10
#define dc 9
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// we will share the hardware SPI interface
ST7735 tft = ST7735(cs, dc, rst);
// connect the SD card with MOSI going to pin 11, MISO going to pin 12 and SCK going to pin 13 (standard)
// Then pin 4 goes to CS (or whatever you have set up)
#define SD_CS 4 // Set the chip select line to whatever you use (4 doesnt conflict with the library)
// the file itself
File bmpFile;
// information we extract about the bitmap file
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
void setup(void) {
pinMode(cs, OUTPUT);
digitalWrite(cs, HIGH);
// initialize a ST7735R TFT
tft.initR();
// Just do a simple test
tft.writecommand(ST7735_DISPON);
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("failed!");
return;
Serial.println("SD OK!");
bmpFile = SD.open("IMAGE.bmp");
if (! bmpFile) {
Serial.println("didnt find image");
while (1);
if (! bmpReadHeader(bmpFile)) {
Serial.println("bad bmp");
return;
Serial.print("image size ");
Serial.print(bmpWidth, DEC);
Serial.print(", ");
Serial.println(bmpHeight, DEC);
bmpdraw(bmpFile, 0, 0);
void testfastlines(uint16_t color1, uint16_t color2) {
tft.fillScreen(BLACK);
for (uint16_t y=0; y < tft.height; y+=5) {
tft.drawHorizontalLine(0, y, tft.width, color1);
for (uint16_t x=0; x < tft.width; x+=5) {
tft.drawVerticalLine(x, 0, tft.height, color2);
#define BUFFPIXEL 20
void bmpdraw(File f, int x, int y) {
bmpFile.seek(bmpImageoffset);
uint32_t time = millis();
uint16_t p;
uint8_t g, b;
int i, j;
uint8_t sdbuffer[3 * BUFFPIXEL]; // 3 * pixels to buffer
uint8_t buffidx = 3*BUFFPIXEL;
//Serial.print("rotation = "); Serial.println(tft.getRotation(), DEC);
//set up the 'display window'
tft.setAddrWindow(x, y, x+bmpWidth-1, y+bmpHeight-1);
uint8_t rotback = tft.getRotation();
//tft.setRotation();
for (i=0; i< bmpHeight; i++) {
for (j=0; j<bmpWidth; j++) {
// read more pixels
if (buffidx >= 3*BUFFPIXEL) {
bmpFile.read(sdbuffer, 3*BUFFPIXEL);
buffidx = 0;
// convert pixel from 888 to 565
b = sdbuffer[buffidx++]; // blue
g = sdbuffer[buffidx++]; // green
p = sdbuffer[buffidx++]; // red
p >>= 3;
p <<= 6;
g >>= 2;
p |= g;
p <<= 5;
b >>= 3;
p |= b;
//Serial.print(p, HEX);
// write out the 16 bits of color
//tft.drawPixel(i, j, p);
tft.pushColor(p);
Serial.print(millis() - time, DEC);
Serial.println(" ms");
boolean bmpReadHeader(File f) {
// read header
uint32_t tmp;
if (read16(f) != 0x4D42) {
// magic bytes missing
return false;
// read file size
tmp = read32(f);
Serial.print("size 0x"); Serial.println(tmp, HEX);
// read and ignore creator bytes
read32(f);
bmpImageoffset = read32(f);
Serial.print("offset "); Serial.println(bmpImageoffset, DEC);
// read DIB header
tmp = read32(f);
Serial.print("header size "); Serial.println(tmp, DEC);
bmpWidth = read32(f);
bmpHeight = read32(f);
if (read16(f) != 1)
return false;
bmpDepth = read16(f);
Serial.print("bitdepth "); Serial.println(bmpDepth, DEC);
if (read32(f) != 0) {
// compression not supported!
return false;
Serial.print("compression "); Serial.println(tmp, DEC);
return true;
// LITTLE ENDIAN!
uint16_t read16(File f) {
uint16_t d;
uint8_t b;
b = f.read();
d = f.read();
d <<= 8;
d |= b;
return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
uint32_t d;
uint16_t b;
b = read16(f);
d = read16(f);
d <<= 16;
d |= b;
return d;
You need to work on your formatting. Curly braces go on lines by themselves, and everything between the braces needs to be properly indented.
It appears that your LCD is controlled entirely by the ST7735 library. If that library supplies a function to power down the LCD, you are in luck. Otherwise, you will need to look through the library, or contact the author, to see how to create such a function.
How does the LCD get power? Can you change when the power source is on?
