TFT LCD Button
I am trying to make a code with the TFT LCD library. The code that i want to make is :
On the display is a rect (It would be button 1) and when I press it It turns ON a led. The problem is that I was searching some examples but i cant find them. I was wondering if someone has a similar code or link to examples or tutorial how it works. I tried to find them but I didnt found them.
Here are the libraries that I am using
#include "TFTLCD.h"
#include "TouchScreen.h"
And I have another Problem, when i am trying to make a rect or something The LCD is doing some buggy things, The Lines are moving up and down.
Post your code (using code tags) that shows the problem.
Are there no examples from wherever you got the libraries ?
I used this code here, but i just tried to see how it works, I took it from paint
code that i used to experiment:
#include "TFTLCD.h"
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 1   // can be a digital pin
#define XP 2   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A5
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
void setup(void) {
 pinMode(13, OUTPUT);
  tft.initDisplay();
  tft.fillScreen(BLACK);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
  tft.fillRect(50,50,50,50,BLUE);
if (p.y > 50 && p.y < 50 && p.x > 50 && p.x < 50){
    //toggle the state of the LED
    if (LED_3_State == HIGH){
      digitalWrite(13, RELAY_ON);
      Tft.fillCircle(219, 120, 16,GREEN);
      LED_3_State = LOW;
i found some examples in other codes , it was just to see, to try to learn how it works
Code that goes with the library as example (it is just paint)
#include "TFTLCD.h"
//Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A4
#define	BLUE            0x001F
#define	RED             0xF800
#define CYAN            0x07FF
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
  Serial.println("Paint!");
  tft.reset();
  uint16_t identifier = tft.readRegister(0x0);
  if (identifier == 0x9325) {
    Serial.println("Found ILI9325");
  } else if (identifier == 0x9328) {
    Serial.println("Found ILI9328");
    Serial.print("Unknown driver chip ");
    Serial.println(identifier, HEX);
    while (1);
  tft.initDisplay();
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
 // tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, WHITE);
 tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
 currentcolor = RED;
  digitalWrite(13, HIGH);
  Point p = ts.getPoint();
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    if (p.y < (TS_MINY-5)) {
      Serial.println("erase");
     // press the bottom of the screen to erase
      tft.fillRect(0, BOXSIZE, tft.width(), tft.height()-BOXSIZE, BLACK);
    // turn from 0->1023 to tft.width
    p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
    p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
    if (p.y < BOXSIZE) {
       oldcolor = currentcolor;
       if (p.x < BOXSIZE) {
         currentcolor = RED;
       else if (p.x < BOXSIZE*2) {
         currentcolor = YELLOW;
         tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*3) {
         currentcolor = GREEN;
         tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*4) {
         currentcolor = CYAN;
         tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*5) {
         currentcolor = BLUE;
         tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, WHITE);
       else if (p.x < BOXSIZE*6) {
         currentcolor = MAGENTA;
         tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, WHITE);
       if (oldcolor != currentcolor) {
          if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
          if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
          if (oldcolor == GREEN) tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
          if (oldcolor == CYAN) tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
          if (oldcolor == BLUE) tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
          if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
    if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
      tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
So i tries with other libraries but id doesen t work just with this one, Paint doesen t work good , X Coordinate is inverted.
I tried to figure it out how it works via paint but i block.
