For my project, the heart rate sensor SEN-11574 ( something like this: https://www.sparkfun.com/products/11574) measures the raw heart values from a user's index finger.
The code makes it so that the raw heart values are converted to pulse rate (BPM), and then the BPM values are displayed in a 1.44" 128X128 SPI Color TFT LCD Module Display (ILI9163) ( something like this: https://www.creatroninc.com/product/144-tft-graphic-lcd-128x128px/)
This original code was written for the sensor values to output to a 2.2″ TFT display.
It's supposed to look like this: Imgur: The magic of the Internet.
And this is the code.
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9340.h"
#define _sclk 13
#define _mosi 11
#define _cs 10
#define _rst 9
#define _dc 8
Adafruit_ILI9340 tft = Adafruit_ILI9340(_cs, _dc, _rst);
int prevCount=1;
int countdigits[] = {
0, 0, 0};
int prevdigits[] = {
0, 0, 0};
int digitpos[] = {
30, 90, 150};
int x=0;
// VARIABLES
int pulsePin = 0; // Pulse Sensor purple wire connected to analog pin 0
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM; // used to hold the pulse rate
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // holds the time between beats, must be seeded!
volatile boolean Pulse = false; // true when pulse wave is high, false when it's low
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
void setup(){
//Start the TFT screen and paint it black
tft.begin();
tft.setRotation(1);
tft.fillScreen(ILI9340_BLACK);
tft.setTextColor(ILI9340_WHITE);
tft.setTextSize(4);
tft.setCursor(230, 90);
tft.print("bpm");
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
void loop(){
if (QS == true){ // Quantified Self flag is true when arduino finds a heartbeat
Serial.print("BPM = ");
Serial.println(BPM);
countdigits[2] = BPM % 10;
//How to handle the middle digit depends on if the
//the speed is a two or three digit number
if(BPM > 99){
countdigits[1] = (BPM / 10) % 10;
else{
countdigits[1] = BPM / 10;
//Grab the first digit
countdigits[0] = BPM / 100;
//Split out the digits of the previous speed
prevdigits[2] = prevCount % 10;
if(prevCount > 99){
prevdigits[1] = (prevCount / 10) % 10;
else{
prevdigits[1] = prevCount / 10;
prevdigits[0] = prevCount / 100;
//Now print the digits on the TFT screen.
//Only execute this block if the bpm has changed.
if(BPM != prevCount){
tft.setTextSize(10);
//Compare each digit to the value from the previous loop.
//The digit will only be redrawn if it has changed.
for(x=0; x < 3; x++){
if(countdigits[x] != prevdigits[x]){
//black out old value first.
//Draw digit in black over the top of white digit
tft.setCursor(digitpos[x], 70);
tft.setTextColor(ILI9340_BLACK);
tft.print(prevdigits[x]);
//print new value in white
if((x == 0) and (BPM > 99) and (countdigits[x] > 0)){
tft.print(countdigits[x]);
if((x == 1) and (BPM >= 99)){
else if((x == 1) and (BPM < 99) and (countdigits[x] > 0)){
if(x == 2){
prevCount = BPM; //Store current bpm for comparison on the next loop.
QS = false; // reset the Quantified Self flag for next time
So I modified the code so that the ordinary TFT library is used.
#include "SPI.h"
#include "TFT.h"
#define _sclk 13
#define _mosi 11
#define _cs 10
#define _dc 9
#define _rst 8
TFT tft = TFT(_cs, _dc, _rst);
int prevCount=1;
0, 0, 0};
0, 0, 0};
int digitpos[] = {
30, 90, 150};
int x=0;
// VARIABLES
void setup(){
tft.begin();
tft.setRotation(1); // basically set the rotation
tft.background(0, 0, 0); // Set background color to black
tft.stroke(255, 255, 255); // set word to white
tft.setTextSize(3);
tft.setCursor(8, 26);
tft.print("bpm");
tft.stroke(255, 255, 255); // Text color is set to white
void loop(){
if(BPM > 99){
else{
if(prevCount > 99){
else{
tft.setTextSize(2);
tft.stroke(0, 0, 0);
if(x == 2){
tft.stroke(255, 255, 255); // set the color to white
but instead, it looks like this Imgur: The magic of the Internet
How can I fix it so that the texts are all aligned? I suspect it has something to do with the digipos[x] section, but I'm a beginner coder, so I don't understand what it means, and when I tried to search up what the code meant, nothing informative came up.
Thank you.
