TFT LCD touch Screen Orientation
Hello,
I have developed some code for my touch screen with rotation at 0 and 2 (portrait)and I am able to press the buttons on the screen as desired ,but after changing the Rotation to 1 or 3 (Landscape) I am not able to click the buttons and somewhere out side of the button I am able press.
Here is the code I have included the results of Touch Calibration from MCUFRIEND_kbv example.
#include "Arduino.h"
#include <TouchScreen.h>
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
// Color definitions
#define ILI9341_BLACK       0x0000      /*   0,   0,   0 */
#define ILI9341_NAVY        0x000F      /*   0,   0, 128 */
#define ILI9341_DARKGREEN   0x03E0      /*   0, 128,   0 */
#define ILI9341_DARKCYAN    0x03EF      /*   0, 128, 128 */
#define ILI9341_MAROON      0x7800      /* 128,   0,   0 */
#define ILI9341_PURPLE      0x780F      /* 128,   0, 128 */
#define ILI9341_OLIVE       0x7BE0      /* 128, 128,   0 */
#define ILI9341_LIGHTGREY   0xC618      /* 192, 192, 192 */
#define ILI9341_DARKGREY    0x7BEF      /* 128, 128, 128 */
#define ILI9341_BLUE        0x001F      /*   0,   0, 255 */
#define ILI9341_GREEN       0x07E0      /*   0, 255,   0 */
#define ILI9341_CYAN        0x07FF      /*   0, 255, 255 */
#define ILI9341_RED         0xF800      /* 255,   0,   0 */
#define ILI9341_MAGENTA     0xF81F      /* 255,   0, 255 */
#define ILI9341_YELLOW      0xFFE0      /* 255, 255,   0 */
#define ILI9341_WHITE       0xFFFF      /* 255, 255, 255 */
#define ILI9341_ORANGE      0xFD20      /* 255, 165,   0 */
#define ILI9341_GREENYELLOW 0xAFE5      /* 173, 255,  47 */
#define ILI9341_PINK        0xF81F
#define ORIENTATION 1
#define BUTTON_X_MainScrn 160
#define BUTTON_Y_MainScrn 120
#define BUTTON_W_MainScrn 150
#define BUTTON_H_MainScrn 50
#define BUTTON_SPACING_X_MainScrn 30
#define BUTTON_SPACING_Y_MainScrn 30
#define BUTTON_TEXTSIZE_MainScrn 2
char currentPage;
#define TEXT_TCOLOR_MainScrn ILI9341_DARKGREY
#define TEXT_TCOLOR_TITL ILI9341_BLUE
// text box where numbers go
#define TEXT_X_MainScrn 110
#define TEXT_Y_MainScrn 10
#define TEXT_TSIZE_MainScrn 2
int debug = 1;
/*uint16_t TS_LEFT = 128;
  uint16_t TS_RT  = 911;
  uint16_t TS_TOP = 942;
  uint16_t TS_BOT = 139;*/
//const int TS_LEFT=165,TS_RT=825,TS_TOP=927,TS_BOT=180;
const int TS_LEFT = 825, TS_RT = 165, TS_TOP = 927, TS_BOT = 180;
/*Screen Calibration Results
TouchScreen.h GFX Calibration
Making all control and bus pins INPUT_PULLUP
Typical 30k Analog pullup with corresponding pin
would read low when digital is written LOW
e.g. reads ~25 for 300R X direction
e.g. reads ~30 for 500R Y direction
Testing : (A2, D8) = 21
Testing : (A3, D9) = 37
Diagnosing as:-
XM,XP:  (A2, D8) = 21
YP,YM:  (A3, D9) = 37
ID = 0x9481
cx=182 cy=957 cz=208 LEFT, TOP, Pressure
cx=193 cy=594 cz=449 LEFT, MIDH, Pressure
cx=180 cy=194 cz=533 LEFT, BOT, Pressure
cx=540 cy=958 cz=344 MIDW, TOP, Pressure
cx=540 cy=198 cz=560 MIDW, BOT, Pressure
cx=880 cy=956 cz=434 RT, TOP, Pressure
cx=887 cy=579 cz=562 RT, MIDH, Pressure
cx=894 cy=211 cz=573 RT, BOT, Pressure
MCUFRIEND_kbv ID=0x9481  320 x 480
const int XP=8,XM=A2,YP=A3,YM=9; //320x480 ID=0x9481
const int TS_LEFT=161,TS_RT=910,TS_TOP=973,TS_BOT=184;
PORTRAIT CALIBRATION     320 x 480
x = map(p.x, LEFT=161, RT=910, 0, 320)
y = map(p.y, TOP=973, BOT=184, 0, 480)
Touch Pin Wiring XP=8 XM=A2 YP=A3 YM=9
LANDSCAPE CALIBRATION    480 x 320
x = map(p.y, LEFT=973, RT=184, 0, 480)
y = map(p.x, TOP=910, BOT=161, 0, 320)
#define TS_MINX 204
#define TS_MAXX 948
#define TS_MINY 195
#define TS_MAXY 910
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button buttonsMainSelection[4];
char buttonlabelsMainSelection[4][9] = {"Throttle", "Loco Stp", "TOutCtrl", "TOutStp"};
uint16_t  buttoncolorsMainSelection[4] = {ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE};
  uint16_t identifier = tft.readID();
  tft.begin(identifier);
  tft.fillScreen(ILI9341_BLACK);
  tft.setRotation(ORIENTATION);
  currentPage = '0';
  drawMainScreen_forSelection();
#define MINPRESSURE 10
#define MAXPRESSURE 1000
void loop(void) {
  TSPoint p = ts.getPoint();
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
  pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  pinMode(YM, OUTPUT);
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    p.x = map(p.y, 973, 184, 0, 480);
    p.y = map(p.x, 910, 161, 0, 320);
  if (currentPage == '0') {
    MainScrButtonPressed(p.x, p.y);
void MainScrButtonPressed(int x, int y) {
    // go thru all the buttons, checking if they were pressed
    for (uint8_t b = 0; b < 4; b++) {
      if (buttonsMainSelection[b].contains(x, y)) {
      Serial.println("(x "); Serial.print(x); Serial.print(",y ");Serial.print(y);  //Serial.print("Pressing: "); Serial.println(b);
        buttonsMainSelection[b].press(true);  // tell the button it is pressed
        buttonsMainSelection[b].press(false);  // tell the button it is NOT pressed
    // now we can ask the buttons if their state has changed
      if (buttonsMainSelection[b].justReleased()) {
        // Serial.print("Released: "); Serial.println(b);
        buttonsMainSelection[b].drawButton();  // draw normal
      if (buttonsMainSelection[b].justPressed()) {
        buttonsMainSelection[b].drawButton(true);  // draw invert!
        //Serial.print("b: "); Serial.println(b);
        // Display Throttle
        if (b == 0) {
          currentPage = '0';
         // tft.fillScreen(ILI9341_BLACK);
        //  drawThrottleControl();
        // Display LocoSetup
        if (b == 1) {
          currentPage = '0';
         // drawLocoID_Setup_Screen();
        // Display TurnOut Control;
        if (b == 2) {
          currentPage = '0';
         // draw_turnout_buttons();
        delay(100); // UI debouncing
void drawMainScreen_forSelection() {
    tft.setCursor(TEXT_X_MainScrn + 2, TEXT_Y_MainScrn + 20);
    tft.setTextColor(TEXT_TCOLOR_TITL, ILI9341_BLACK);
    tft.setTextSize(TEXT_TSIZE_MainScrn);
    tft.print("   Model Train Controller");
    tft.setTextColor(TEXT_TCOLOR_MainScrn, ILI9341_BLACK);
    tft.setCursor(TEXT_X_MainScrn + 2, TEXT_Y_MainScrn + 35);
    tft.print("Press a button to proceed");
    tft.drawLine(0, 62, tft.width(), 62, ILI9341_DARKCYAN);
    // create buttons
    for (uint8_t row = 0; row < 2; row++) {
      for (uint8_t col = 0; col < 2; col++) {
        buttonsMainSelection[col + row * 2] .initButton(&tft, BUTTON_X_MainScrn + col * (BUTTON_W_MainScrn + BUTTON_SPACING_X_MainScrn),
            BUTTON_Y_MainScrn + row * (BUTTON_H_MainScrn + BUTTON_SPACING_Y_MainScrn), // x, y, w, h, outline, fill, text
            BUTTON_W_MainScrn, BUTTON_H_MainScrn, ILI9341_WHITE, buttoncolorsMainSelection[col + row * 2], ILI9341_WHITE,
            buttonlabelsMainSelection[col + row * 2], BUTTON_TEXTSIZE_MainScrn);
            buttonsMainSelection[col + row * 2].drawButton();
