n1k0o9
December 17, 2022, 7:39pm
1
Hi everyone
I want to display something on TFT 1.8 st 7735 LCD with esp 32. First of all, if you know a good source for training, please introduce me, but I put the following code as a test on esp 32 and received the following error.
"compiling for board esp 32 dev module"
(The connections of an esp 32 are correct because other codes are uploaded on it, but for this code I receive the following error code)
my IDE Version 1.8.19
// include TFT and SPI libraries
#include <TFT.h>
#include <SPI.h>
// pin definition for Arduino UNO
#define cs 21
#define dc 2
#define rst 4
// create an instance of the library
TFT TFTscreen = TFT(cs, dc, rst);
//initialize the library
TFTscreen.begin();
// clear the screen with a black background
TFTscreen.background(0, 0, 0);
//set the text size
TFTscreen.setTextSize(2);
//generate a random color
int redRandom = random(0, 255);
int greenRandom = random (0, 255);
int blueRandom = random (0, 255);
// set a random font color
TFTscreen.stroke(redRandom, greenRandom, blueRandom);
// print Hello, World! in the middle of the screen
TFTscreen.text("Hello, World!", 6, 57);
// wait 200 miliseconds until change to next color
delay(200);
n1k0o9, welcome to the forum.
Perhaps you missed some of the error message?
That text is not an error message, just information. Was there anything else?
red_car
December 17, 2022, 8:08pm
3
Is this the error?
Arduino: 1.8.16 (Mac OS X), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/paulibbotson/Library/Arduino15/packages -hardware /Users/paulibbotson/Documents/Arduino/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/paulibbotson/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/paulibbotson/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10816 -build-path /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486 -warnings=all -build-cache /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_cache_691706 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.mkspiffs.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -verbose /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/paulibbotson/Library/Arduino15/packages -hardware /Users/paulibbotson/Documents/Arduino/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/paulibbotson/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/paulibbotson/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10816 -build-path /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486 -warnings=all -build-cache /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_cache_691706 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/esptool_py/4.2.1 -prefs=runtime.tools.mkspiffs.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -verbose /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621/Blink.ino
Using board 'esp32' from platform in folder: /Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5
Using core 'esp32' from platform in folder: /Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5
bash -c "[ ! -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/partitions.csv ] || cp -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/partitions.csv \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/partitions.csv"
bash -c "[ -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/partitions.csv ] || [ ! -f \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/partitions.csv ] || cp \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/partitions.csv \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/partitions.csv"
bash -c "[ -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/partitions.csv ] || cp \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5\"/tools/partitions/default.csv \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/partitions.csv"
bash -c "[ -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/bootloader.bin ] && cp -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/bootloader.bin \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/Blink.ino.bootloader.bin || ( [ -f \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/bootloader.bin ] && cp \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32\"/bootloader.bin \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/Blink.ino.bootloader.bin || \"/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/esptool_py/4.2.1\"/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/Blink.ino.bootloader.bin \"/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5\"/tools/sdk/esp32/bin/bootloader_qio_80m.elf )"
esptool.py v4.2.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
bash -c "[ ! -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/build_opt.h ] || cp -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621\"/build_opt.h \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/build_opt.h"
bash -c "[ -f \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/build_opt.h ] || touch \"/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486\"/build_opt.h"
Detecting libraries used...
/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/build_opt.h -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/sketch/Blink.ino.cpp -o /dev/null
Alternatives for TFT.h: [TFT@1.0.6]
ResolveLibrary(TFT.h)
-> candidates: [TFT@1.0.6]
/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/build_opt.h -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 -I/Applications/Arduino.app/Contents/Java/libraries/TFT/src /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/sketch/Blink.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@2.0.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@2.0.0]
/Users/paulibbotson/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/newlib/platform_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/heap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/log/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/soc/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/hal/platform_port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/soc -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/driver/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_pm/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/efuse/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/vfs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_wifi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_event/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_netif/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_eth/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_ipc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_trace/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_timer/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/app_update/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spi_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bootloader_support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nvs_flash/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/pthread/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ieee802154/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/console -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/asio/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/osi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cbor/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/unity/unity/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/cmock/CMock/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/coap/libcoap/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_hid/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/tcp_transport/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_http_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_ota/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_https_server/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_lcd/interface -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/common -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/security -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/protocomm/include/transports -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mdns/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/sdmmc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/expat/port/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wear_levelling/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/diskio -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/vfs -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fatfs/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/freemodbus/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/jsmn/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json/cJSON -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/libsodium/port_include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/openssl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/perfmon/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/spiffs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ulp/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/rmaker_common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_parser/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/json_generator/upstream -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_schedule/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/gpio_button/button/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/qrcode/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/ws2812_led -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp_littlefs/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/image -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/math -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/src/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/include/fb_gfx/include -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/build_opt.h -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/cores/esp32 -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/variants/esp32 -I/Applications/Arduino.app/Contents/Java/libraries/TFT/src -I/Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/SPI/src /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_build_754486/sketch/Blink.ino.cpp -o /dev/null
Alternatives for avr/pgmspace.h: []
ResolveLibrary(avr/pgmspace.h)
-> candidates: []
In file included from /Applications/Arduino.app/Contents/Java/libraries/TFT/src/TFT.h:37,
from /var/folders/4z/3g9th3gs4cng3b803dg5bhw40000gn/T/arduino_modified_sketch_634621/Blink.ino:2:
/Applications/Arduino.app/Contents/Java/libraries/TFT/src/utility/Adafruit_ST7735.h:30:10: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
compilation terminated.
Using library TFT at version 1.0.6 in folder: /Applications/Arduino.app/Contents/Java/libraries/TFT
Using library SPI at version 2.0.0 in folder: /Users/paulibbotson/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/SPI
exit status 1
Error compiling for board ESP32 Dev Module.
Looks like the TFT library you are using is not compatible with an ESP32. Maybe try the TFT_eSPI library... you'll need to change your code to match.
Your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem
Try this library. Or like red_car say the TFT_eSPI library from Bodmer. The last is a little more difficult.
SDI on MOSI IO23?
SDO on MISO (optional) IO19?
CLK on SCK IO18?
n1k0o9
December 27, 2022, 3:52pm
6
Thanks to everyone, I was able to solve this problem with the TFT espi library
system
Closed
June 25, 2023, 3:53pm
7
