Tft lcd with esp23
i wanted to try and use this code with an esp23 devkit, i originally coded this on an arduino uno. Am i able to just transfer the code over to the esp23, or do i need to change it? if i need to change would i need to rewrite the whole code again or is there a library i can use that will only require small changes and allow to use the same code and format
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
// these pins define the pins being used by the Arduino^^
#define TS_MINX 118
#define TS_MINY 106
#define TS_MAXX 950
#define TS_MAXY 933
#define YP A3
#define XM A2
#define YM 9
#define XP 8
// this code calibrates the screen
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// these define the pins used to activate the screen, i believe that the 300 is the Maximum resistence of the screen
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xf81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
//transmitter
RF24 radio(10, 7);  // CE, CSN
const byte address[6] = ("TEXTC");
const char txt[] = "Connection made";
struct Data_P {
  bool touchvar = false;
  char text[sizeof(txt)];
Data_P data;
int currentscreen = 0;
bool Camera = 0;
bool tracker = false;
bool Homevar = false;
bool backbutton = 1;
bool welcome = true;
// A touch variable that will switch depending on parameters for radio communication
void Home() {
  tft.fillScreen(RED);
  tft.setCursor(60, 100);
  tft.setTextSize(2);
  tft.print("CHOOSE APPLICATION");
  tft.fillRect(10, 10, 75, 75, BLUE);
  tft.fillRect(125, 10, 75, 75, BLUE);
  tft.fillRect(240, 10, 75, 75, BLUE);
  // creating buttons for applications, first test out using LED's
void Welcome() {
  tft.fillScreen(WHITE);                //WHat to fill the screen colour with- colours stated above
  tft.drawRect(0, 0, 319, 240, WHITE);  //the rectangularshape that the screen fills
  tft.setCursor(5, 5);                  //set cursor is where text will begin on the screen, top right corner of the text
  tft.setTextColor(BLACK);
  tft.setTextSize(2);
  tft.print("WELCOME LKAT");
  //add parameters
  tft.fillRect(50, 180, 210, 40, BLACK);
  tft.drawRect(50, 180, 210, 40, GREEN);
  tft.setCursor(60, 190);
  tft.setTextColor(WHITE);
  tft.setTextSize(2);
void LEDB() {
  tft.fillScreen(BLUE);
  tft.print("HELLO");
void LEDR() {
  tft.print("HELLO");
  radio.begin();
  radio.openWritingPipe(address);  //00001
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  tft.reset();
  uint16_t identifier = tft.readID();
  tft.begin(identifier);
  tft.setRotation(3);  //changing this value between 1 and 0 will change the layout of the text on screen. landscape portarait
  currentscreen = 0;
  Welcome();
bool buttonPressed(const int x, const int y, const int buttonX, const int buttonY, const int buttonWidth, const int buttonHeight) {
  return ((x >= buttonX) && (x <= buttonX + buttonWidth) && (y >= buttonY) && (y <= buttonY + buttonHeight));
  TSPoint p = ts.getPoint();
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  radio.write(&data, sizeof(Data_P));
  if (p.z > ts.pressureThreshhold) {
    data.touchvar = !data.touchvar;
    strcpy(data.text, txt);
    Serial.print("\tPressure = ");
    Serial.println(p.z);
    int y = map(p.x, TS_MINX, TS_MAXX, 0, 240);
    int x = map(p.y, TS_MINY, TS_MAXY, 0, 320);
    serial.print("y value");
serial.println(y);
    // delay(1000);
    if (welcome == true) {
      if (currentscreen == 0) {
        if (buttonPressed(x, y, 50, 180, 210, 40)) {  // x and y map variables and then the starting x,y coordinate and then width and then hieght
          currentscreen = 1;
          welcome = false;
          Homevar = true;
          Home();
    if (currentscreen == 1) {
      if (Homevar == true && welcome == false) {
        if (buttonPressed(x, y, 10, 10, 75, 75)) {  // starting xy coord and then width and height
          LEDB();
          currentscreen = 2;
          //if(currentscreen==2 && buttonPressed(x,y,0,0,319,240)){//tft.darwRect(0,0,319,240);
        } else if (buttonPressed(x, y, 125, 10, 75, 75)) {
          LEDR();
          currentscreen = 3;
        } else if (buttonPressed(x, y, 240, 10, 75, 75)) {
          tft.fillScreen(GREEN);
          currentscreen = 4;
          if (currentscreen = 4) {
I moved your topic to a more appropriate forum category @lkat.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
First get the TFT working with the ESP32. You should have no major problems, but until you state which components you have and how they are wired, forum members can't even guess.
Then add other components one by one, testing as you go, to make sure there are no pin conflicts.
