So I recently got my Arduino Giga R1 I've been trying to connect a tft display to it using the MCUFRIEND_kbv library but it has not been working. it gives me a long list of errors. I have used this library with the Arduino Due so I know it works.
I have tried the example I get the same error.
#define WriteCmd(x) { CD_COMMAND; write16(x); CD_DATA; }
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: note: suggested alternative: 'write24'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: note: in definition of macro 'WriteCmd'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1213:20: error: 'PIN_HIGH' was not declared in this scope
#define CD_DATA PIN_HIGH(CD_PORT, CD_PIN)
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1213:20: note: in definition of macro 'CD_DATA'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:122:5: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1213:20: note: suggested alternative: 'HIGH'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: error: 'write8' was not declared in this scope
write8(u8);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: note: suggested alternative: 'write'
write8(u8);
write
In file included from c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:38:0:
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:28: error: 'CD_PORT' was not declared in this scope
#define CD_COMMAND PIN_LOW(CD_PORT, CD_PIN)
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:28: note: in definition of macro 'CD_COMMAND'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:128:13: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:28: note: suggested alternative: 'STM_PORT'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:37: error: 'CD_PIN' was not declared in this scope
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:37: note: in definition of macro 'CD_COMMAND'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:37: note: suggested alternative: 'STM_PIN'
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: error: 'write16' was not declared in this scope
WriteCmd(cmd);
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:20: error: 'PIN_HIGH' was not declared in this scope
#define CS_IDLE PIN_HIGH(CS_PORT, CS_PIN)
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:20: note: in definition of macro 'CS_IDLE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:20: note: suggested alternative: 'HIGH'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'uint16_t read16bits()':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: error: 'READ_8' was not declared in this scope
READ_8(ret);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: note: suggested alternative: 'PE_8'
READ_8(ret);
PE_8
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readReg(uint16_t, int8_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:28: error: 'CS_PORT' was not declared in this scope
#define CS_ACTIVE PIN_LOW(CS_PORT, CS_PIN)
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:28: note: in definition of macro 'CS_ACTIVE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:28: note: suggested alternative: 'STM_PORT'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:37: error: 'CS_PIN' was not declared in this scope
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:37: note: in definition of macro 'CS_ACTIVE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:37: note: suggested alternative: 'SPI1'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:20: error: 'PIN_LOW' was not declared in this scope
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:20: note: in definition of macro 'CS_ACTIVE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:20: note: suggested alternative: 'PIN_LED'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:169:5: note: in expansion of macro 'WriteCmd'
WriteCmd(reg);
WriteCmd(reg);
WriteCmd(reg);
WriteCmd(reg);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: note: suggested alternative: 'write'
WriteCmd(reg);
WriteCmd(reg);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: error: 'setReadDir' was not declared in this scope
setReadDir();
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: note: suggested alternative: 'seekdir'
setReadDir();
seekdir
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:29: error: 'RD_PORT' was not declared in this scope
#define RD_IDLE PIN_HIGH(RD_PORT, RD_PIN)
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:29: note: in definition of macro 'RD_IDLE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:29: note: suggested alternative: 'STM_PORT'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:38: error: 'RD_PIN' was not declared in this scope
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:38: note: in definition of macro 'RD_IDLE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:38: note: suggested alternative: 'STM_PIN'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:20: error: 'PIN_HIGH' was not declared in this scope
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:20: note: in definition of macro 'RD_IDLE'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:20: note: suggested alternative: 'HIGH'
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: error: 'setWriteDir' was not declared in this scope
setWriteDir();
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: note: suggested alternative: 'setWriteError'
setWriteDir();
setWriteError
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:165:13: warning: unused variable 'lo' [-Wunused-variable]
uint8_t lo;
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readID()':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:264:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (ret == 0x1526) //R61526 [xx 06 15 26] if I have written NVM
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:266:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'if'
if (ret == 0x89F0) //ST7735S: [xx 7C 89 F0]
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:197:19: warning: unused variable 'ret2' [-Wunused-variable]
uint16_t ret, ret2;
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'int16_t MCUFRIEND_kbv::readGRAM(int16_t, int16_t, uint16_t*, int16_t, int16_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:311:9: note: in expansion of macro 'WriteCmd'
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
WriteCmd(_MR);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: error: 'setReadDir' was not declared in this scope
setReadDir();
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: note: suggested alternative: 'seekdir'
setReadDir();
seekdir
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: error: 'READ_8' was not declared in this scope
READ_8(r);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: note: suggested alternative: 'PE_8'
READ_8(r);
PE_8
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: error: 'READ_16' was not declared in this scope
READ_16(dummy);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: note: suggested alternative: 'READ_REG'
READ_16(dummy);
READ_REG
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: error: 'READ_8' was not declared in this scope
if (_lcd_ID == 0x1511) READ_8(r); //extra dummy for R61511
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: note: suggested alternative: 'PE_8'
PE_8
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: error: 'READ_8' was not declared in this scope
READ_8(r);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: note: suggested alternative: 'PE_8'
READ_8(r);
PE_8
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: error: 'READ_16' was not declared in this scope
READ_16(ret);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: note: suggested alternative: 'READ_REG'
READ_16(ret);
READ_REG
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: error: 'setWriteDir' was not declared in this scope
setWriteDir();
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: note: suggested alternative: 'setWriteError'
setWriteDir();
setWriteError
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:300:22: warning: unused variable 'tmp' [-Wunused-variable]
uint8_t r, g, b, tmp;
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::setRotation(uint8_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:361:29: warning: unused variable 'REV' [-Wunused-variable]
uint16_t GS, SS_v, ORG, REV = _lcd_rev, NL;
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::drawPixel(int16_t, int16_t, uint16_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:541:30: note: in expansion of macro 'WriteCmd'
if (is9797) { CS_ACTIVE; WriteCmd(_MW); write24(color); CS_IDLE;} else
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:616:5: note: in expansion of macro 'WriteCmd'
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
WriteCmd(_MW);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: error: 'write8' was not declared in this scope
write8(r);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: note: suggested alternative: 'write'
write8(r);
write
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: error: 'write8' was not declared in this scope
write8(hi);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: note: suggested alternative: 'write'
write8(hi);
write
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void pushColors_any(uint16_t, uint8_t*, int16_t, bool, uint8_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:684:9: note: in expansion of macro 'WriteCmd'
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
WriteCmd(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: error: 'write16' was not declared in this scope
write16(color);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: note: suggested alternative: 'write24'
write16(color);
write24
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: error: 'write16' was not declared in this scope
write16(color);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: note: suggested alternative: 'write24'
write16(color);
write24
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void init_table(const void*, int16_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: error: 'write8' was not declared in this scope
write8(cmd);
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: note: suggested alternative: 'write'
write8(cmd);
write
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::begin(uint16_t)':
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1295:30: warning: unused variable 'SSD1963_NHD_50_regValues' [-Wunused-variable]
static const uint8_t SSD1963_NHD_50_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1310:30: warning: unused variable 'SSD1963_NHD_70_regValues' [-Wunused-variable]
static const uint8_t SSD1963_NHD_70_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1352:30: warning: unused variable 'SSD1963_800NEW_regValues' [-Wunused-variable]
static const uint8_t SSD1963_800NEW_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1376:30: warning: unused variable 'SSD1963_800ALT_regValues' [-Wunused-variable]
static const uint8_t SSD1963_800ALT_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1400:30: warning: unused variable 'SSD1963_480_regValues' [-Wunused-variable]
static const uint8_t SSD1963_480_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1638:31: warning: unused variable 'ST7781_regValues' [-Wunused-variable]
static const uint16_t ST7781_regValues[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:1738:30: warning: unused variable 'ST7789_regValues_arcain6' [-Wunused-variable]
static const uint8_t ST7789_regValues_arcain6[] PROGMEM = {
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2657:30: warning: unused variable 'ILI9341_regValues_ada' [-Wunused-variable]
static const uint8_t ILI9341_regValues_ada[] PROGMEM = { // Adafruit_TFTLCD only works with EXTC=0
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2737:30: warning: unused variable 'ILI9481_CPT29_regValues' [-Wunused-variable]
static const uint8_t ILI9481_CPT29_regValues[] PROGMEM = { // 320x430
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2749:30: warning: unused variable 'ILI9481_PVI35_regValues' [-Wunused-variable]
static const uint8_t ILI9481_PVI35_regValues[] PROGMEM = { // 320x480
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2761:30: warning: unused variable 'ILI9481_AUO317_regValues' [-Wunused-variable]
static const uint8_t ILI9481_AUO317_regValues[] PROGMEM = { // 320x480
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2772:30: warning: unused variable 'ILI9481_CMO35_regValues' [-Wunused-variable]
static const uint8_t ILI9481_CMO35_regValues[] PROGMEM = { // 320480
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2786:30: warning: unused variable 'ILI9481_RGB_regValues' [-Wunused-variable]
static const uint8_t ILI9481_RGB_regValues[] PROGMEM = { // 320x480
c:\Users\David\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:2878:7: warning: label 'common_9488' defined but not used [-Wunused-label]
common_9488:
exit status 1
Compilation error: exit status 1
Given that the Giga R1 was only released 6 months ago, and that the MCUFRIEND_kbv library hasn't been updated in a year, I think it's entirely possible that library will need to be updated before it works with the new board.
Okay thanks for the info
