I have arduino uno with 3.5"(?) tft touchscreen and using MCUFRIEND_KBV library
Screen itself is working and buttons do work but when I add my rotary encoder to it, the buttons stop working and screen does not respond to touch.
#if 1
#include <Arduino.h>
#include <RotaryEncoder.h>
#define PIN_IN1 12
#define PIN_IN2 13
#define ROTARYSTEPS 0
#define ROTARYMIN -360
#define ROTARYMAX 360
RotaryEncoder encoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::TWO03);
int lastPos = -1;
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
#include <FreeDefaultFonts.h>
#define MINPRESSURE 50
#define MAXPRESSURE 1000
void(* resetFunc) (void) = 0;
// ALL Touch panels and wiring is DIFFERENT
// copy-paste results from TouchScreen_Calibr_native.ino
const int XP = 7, XM = A1, YP = A2, YM = 6; //240x320 ID=0x6809
const int TS_LEFT = 928, TS_RT = 105, TS_TOP = 63, TS_BOT = 918;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 400);
Adafruit_GFX_Button on_btn, off_btn, on1_btn, off1_btn, stop_btn;
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define NAVY 0x000F
#define DARKGREEN 0x03E0
#define DARKCYAN 0x03EF
#define MAROON 0x7800
#define PURPLE 0x780F
#define OLIVE 0x7BE0
#define LIGHTGREY 0xC618
#define DARKGREY 0x7BEF
#define BLUE 0x001F
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define ORANGE 0xFD20
#define GREENYELLOW 0xAFE5
#define PINK 0xF81F
void setup(void)
pinMode(10, OUTPUT); // Motor pin 1
pinMode(11, OUTPUT); // Motor pin 2
uint16_t ID = tft.readID();
if (ID == 0xD3D3) ID = 0x9486; // write-only shield
tft.begin(ID);
tft.setRotation(0); //PORTRAIT
tft.fillScreen(BLACK);
on_btn.initButton(&tft, 60, 250, 115, 40, LIGHTGREY, LIGHTGREY, BLACK, "R-LEFT", 2);
off_btn.initButton(&tft, 180, 250, 115, 40, LIGHTGREY, LIGHTGREY, BLACK, "R-RIGHT", 2);
on1_btn.initButton(&tft, 60, 299, 115, 40, LIGHTGREY, LIGHTGREY, BLACK, "SWR / PWR", 2);
off1_btn.initButton(&tft, 180, 299, 115, 40, LIGHTGREY, LIGHTGREY, BLACK, "RESET", 2);
stop_btn.initButton(&tft, 120, 205, 235, 40, LIGHTGREY, LIGHTGREY, RED, "STOP!", 2);
on_btn.drawButton(false);
off_btn.drawButton(false);
on1_btn.drawButton(false);
off1_btn.drawButton(false);
stop_btn.drawButton(false);
tft.fillRect(0, 0, 240, 80, DARKGREY);
void rot(void) {
for (int i = 0; i < 1000000; i++) {
encoder.tick();
int newPos = encoder.getPosition() * 0.75;
if (newPos < ROTARYMIN) {
analogWrite(10, 0);
analogWrite(11, 0);
newPos = ROTARYMIN;
} else if (newPos > ROTARYMAX) {
analogWrite(10, 0);
analogWrite(11, 0);
newPos = ROTARYMAX;
if (lastPos != newPos) {
Serial.println(newPos);
lastPos = newPos;
tft.setTextColor(GREEN, BLACK);
tft.setTextSize(2);
tft.setCursor(5, 120);
tft.print(newPos);
tft.print(" ");
void loop(void)
bool down = Touch_getXY();
showmsgXY(65, 10, 3, NULL, "OH1CJO");
showmsgXY(30, 40, 2, NULL, "Antenna rotator");
showmsgXY(30, 60, 2, NULL, "SWR / PWR meter");
showmsgXY2(5, 85, 1, NULL, "OUTSIDE TEMP: 5c");
showmsgXY2(142, 85, 1, NULL, "INSIDE TEMP: 21c");
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
on1_btn.press(down && on1_btn.contains(pixel_x, pixel_y));
off1_btn.press(down && off1_btn.contains(pixel_x, pixel_y));
stop_btn.press(down && stop_btn.contains(pixel_x, pixel_y));
if (on_btn.justReleased())
on_btn.drawButton();
if (off_btn.justReleased())
off_btn.drawButton();
if (on1_btn.justReleased())
on1_btn.drawButton();
if (off1_btn.justReleased())
off1_btn.drawButton();
if (stop_btn.justReleased())
stop_btn.drawButton();
if (stop_btn.justPressed()) {
stop_btn.drawButton(true);
analogWrite(10, 0);
analogWrite(11, 0);
tft.setTextColor(RED, BLACK);
tft.setTextSize(2);
tft.setCursor(10, 100);
tft.print(" STOPPED! ");
if (on_btn.justPressed()) {
on_btn.drawButton(true);
analogWrite(10, 100);
analogWrite(11, 0);
tft.setTextSize(2);
tft.setCursor(25, 100);
tft.print(" Rotating left! ");
if (off_btn.justPressed()) {
off_btn.drawButton(true);
analogWrite(11, 100);
analogWrite(10, 0);
tft.setTextSize(2);
tft.print(" Rotating right! ");
if (on1_btn.justPressed()) {
on1_btn.drawButton(true);
tft.setTextColor(WHITE, BLACK);
tft.setTextSize(2);
tft.print("SWR / PWR METER!");
if (off1_btn.justPressed()) {
off1_btn.drawButton(true);
resetFunc();
rot();
#endif
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
int16_t x1, y1;
uint16_t wid, ht;
tft.setFont(f);
tft.setCursor(x, y);
tft.setTextColor(BLACK);
tft.setTextSize(sz);
tft.print(msg);
void showmsgXY2(int x, int y, int sz, const GFXfont *f, const char *msg)
int16_t x1, y1;
uint16_t wid, ht;
tft.setFont(f);
tft.setTextColor(WHITE);
tft.print(msg);
Here is my code. at the end of the loop, there is rot();
its the encoder part thats needs to show the value on the screen all the time. if I remove the rot();
the screen starts working and buttons start working.
if I add the rot(); under the "R-LEFT" button then everything works until I press R-LEFT button. Then it starts showing the encoder value and no buttons work anymore.
How can I fix this?
I tried something like:
void rot(void){
static unsigned long nextReport = 0;
if ((signed long)(millis() - nextReport) <=0 )
return ;
nextReport = millis() + 100;
encoder.tick();
analogWrite(10, 0);
analogWrite(11, 0);
newPos = ROTARYMIN;
analogWrite(10, 0);
analogWrite(11, 0);
newPos = ROTARYMAX;
lastPos = newPos;
tft.setTextSize(2);
tft.print(newPos);
tft.print(" ");
but with this, the encoder value does not change at all. everything is frozen.
tldr: The screen buttons need to be working and the encoder value has to refresh
at the moment it is bad to turn antenna because I press "motor turn" button, the antenna starts turning and I cannot stop it. It stops when encoder reads 360 degree.
//edit. also if someone know this mcufriend_kbv library then how can I change "round" buttons to square?
Like the button edges are round. I want to change them straight 90degree. Have not figured it out how to.
