i'm trying to implement an EEG monitoring system using arduino and Mindflex and a some leds.i used a fonciton to read and compare the data got from the mindflex and return one String of the State we reading but when i try to print it on the tft it shows the messages over each other like this.
#include <RA8875.h>
#define RA8875_INT 4
#define RA8875_CS 10
# define RA8875_RESET 9
#include <Brain.h>
#include <Arduino.h>
#include <String.h>
//declaring the pins
#define RELAY1 3
#define RELAY2 9
#define RELAY3 10
#define RELAY4 2
#define RELAY5 11
#define RELAY6 12
RA8875 tft = RA8875(RA8875_CS,RA8875_RESET);
Brain brain(Serial);
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
pinMode(RELAY5, OUTPUT);
pinMode(RELAY6, OUTPUT);
Serial.println("RA8875 start");
tft.begin(RA8875_480x272);
tft.fillWindow(RA8875_BLACK);// initialize a ST7735S chip, black tab
long tab[6];
int ti[2];
String msg;
if (brain.update()) {
if (brain.readSignalQuality() > 100) {
tft.setCursor(0,30);
tft.setTextColor(RA8875_RED,RA8875_BLACK);
tft.println("signal quality low");
else {
tab[0] = map (brain.readDelta (),300000,500000,0,1023);
tab[1] = map (brain.readTheta(),10000,29000,0,1023);
tab[2] = map (brain.readLowAlpha(),30000,40000,0,1023);
tab[3] = map (brain.readHighAlpha(),6000,9000,0,1023);
tab[4] = map (brain.readLowBeta(),4000,8800,0,1023);
tab[5] = map (brain.readLowGamma(),700000,900000,0,1023);
ti[0]=brain.readSignalQuality();
ti[1]=brain.readAttention();
ti[2]=brain.readMeditation();
lam(ti);
msg=writeComp(compar(tab,6));
Print(ti,6,msg);
///////////////////////////////////////////////////////Fonctions/////////////////////////////////////////
int compar(long* array, int size){ //fcontion to compare the inputs taht we put in an array and return the index of the max
int maxIndex = 0;
int max = array[maxIndex];
for (int i=1; i< size; i++){
if (max<array[i]){
max = array[i];
maxIndex = i;
return maxIndex;
String writeComp (int val){// here is a fonction to make the use of the index of the max and use it to create a message to write once onll te reduce the time of computation
String mess;
switch (val) {
case 0 :
mess=String("Sleeep") ;
case 1 :
mess =String("Relaxed, mediative");
case 2 :
mess=String("Relaxed, eyes closed");
case 3 :
mess=String(" power value");
case 4 :
mess=String(" alert, foucsed");
case 5:
mess=String("multi sensing");
default:
mess=String("ERROR ");
break;}
return mess;
void lam(int* b){
if (b[0] < 25) {
if (b[1] < 50) {
digitalWrite( RELAY1, HIGH);
digitalWrite( RELAY2, LOW);
digitalWrite( RELAY3, LOW);
else if (b[1] >70)
digitalWrite( RELAY2, HIGH);
digitalWrite( RELAY1, LOW);
else if (b[1] < 70 and b[1] > 50)
digitalWrite( RELAY3, HIGH);
void lamp (int b){
if ( 10 > b){
digitalWrite(RELAY1,1);
digitalWrite(RELAY2,1);
digitalWrite(RELAY3,1);
digitalWrite(RELAY4,1);
digitalWrite(RELAY5,1);
digitalWrite(RELAY6,1);}
else if (20 >= b <= 45)
{digitalWrite(RELAY1,0);
digitalWrite(RELAY2,0);
digitalWrite(RELAY3,0); }
else if (45 <= b >= 75){
digitalWrite(RELAY4,0);
digitalWrite(RELAY5,0);
digitalWrite(RELAY6,0);}
else if (b < 75){
void Print(int* ar, int size,String m){
tft.setCursor(30,0);
tft.setTextColor(RA8875_WHITE);
tft.setFontScale(0);
tft.println("Brain states mapping system");
tft.setCursor(0, 30);
tft.setTextColor(RA8875_YELLOW,RA8875_WHITE);
tft.print("signal quality :");
tft.print(ar[0]);
tft.println(" ");
tft.setTextColor(RA8875_RED,RA8875_WHITE);
tft.print("Attention :");
tft.print(ar[1]);
tft.println(" ");
tft.setTextColor(RA8875_BLACK,RA8875_WHITE);
tft.print("Meditation :");
tft.print(ar[2]);
tft.println(" ");
tft.print("The actual state is : ");
tft.print(m);
tft.println(" ");
