TFT Programming problem
TFT Programming
Today at 02:57 pm
I am new to arduino and I am using arduino uno, SD card reader, and 4.3 TFT (Sainsmart) When I am verify, I am getting ('sensorPrintout' was not delared in this scope) error.
The code line is (TFTscreen.text(sensorPrintout,0,20);.
I am not sure what this means.
#include <SPI.h>
#include <TFT.h>
#define cs 10
#define dc 9
#define rst 8
TFT TFTscreen = TFT(cs, dc, rst);
TFTscreen.begin();
TFTscreen.background(0, 0, 0);
TFTscreen.stroke(255,255,255);
TFTscreen.setTextSize(2);
TFTscreen.text("Sensor Value : ",0,0);
TFTscreen.setTextSize(5);
String sensorVal = String(analogRead(A0));
TFTscreen.text(sensorPrintout, 0, 20);
delay(250);
TFTscreen.stroke(0,0,0);
Arduino TFT text example
This example demonstrates how to draw text on the
TFT with an Arduino. The Arduino reads the value
of an analog sensor attached to pin A0, and writes
the value to the LCD screen, updating every
quarter second.
This example code is in the public domain
Created 15 April 2013 by Scott Fitzgerald
#include <TFT.h> // Arduino LCD library
#include <SPI.h>
// pin definition for the Uno
#define cs 10
#define dc 9
#define rst 8
// pin definition for the Leonardo
// #define cs 7
// #define dc 0
// #define rst 1
// create an instance of the library
// char array to print to the screen
char sensorPrintout[4];
// Put this line at the beginning of every sketch that uses the GLCD:
TFTscreen.begin();
// clear the screen with a black background
// write the static text to the screen
// set the font color to white
TFTscreen.stroke(255, 255, 255);
// set the font size
// write the text to the top left corner of the screen
TFTscreen.text("Sensor Value :\n ", 0, 0);
// ste the font size very large for the loop
// Read the value of the sensor on A0
// convert the reading to a char array
sensorVal.toCharArray(sensorPrintout, 4);
// print the sensor value
// wait for a moment
delay(250);
// erase the text you just wrote
TFTscreen.stroke(0, 0, 0);
it means you forgot this line:
also, go back and add 'code' tags to make it legible. If you don't know how to do this then you might try looking at: How to use this forum
