Hello,
I just wrote my first TFT program/game - tic tac toe. I am using 2.8" TFT Touch Shield for Arduino with Resistive Touch Screen from Adafruit Datasheet
This is my first foray and I see some decent cleanup I could do. I plan to have 8th graders use this to backwards design their own version, hence the abundance of comments
Anyway, I seem to be getting additional inputs occurring. For example, most times I push the New Game button, the screen reloads the board multiple times. Also, many times I get a new game starting with an X or even an X and O in places pushed at the end of the game. I don't see where the code is interfering, perhaps something I am missing for purging point inputs?
Thanks!
I removed a bunch of code so it would fit here.
// See if there's any touch data for us
// Don't worry about this too much, this will always be needed on this screen.
if (ts.bufferEmpty()) {
return;
//Retrieve a point. This gets the coordinates of where the screen was touched.
TS_Point p = ts.getPoint();
// Scale from ~0->4000 to tft.width using the calibration #'s
// This converts the coordinates of the touched point to between (0,0) and (240,320)
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
// Prints the (x,y) coordinate to the serial monitor. The serial monitor is the magnifying glass in the top right. It is used to help "de-bug" the program.
Serial.print("(");
Serial.print(p.x); // p.x means, give me the x coordinate of the point!
Serial.print(", ");
Serial.print(p.y); // p.x means, give me the x coordinate of the point!
Serial.println(")");
// This is where we will check the location of our touches against the boxes of our grid
// Since I am a math teacher, lets use some matrices to talk about locations. [0,0] will be the first row and first column, so the top left box.
// Notice I used 0's not 1. In programming, we usually use 0 indexes, which starts counting at 0 instead of 1.
if(p.y < BOXSIZE) // Check if the player chose a box in the top row
if(p.x < BOXSIZE && cellStatus[0].cellChosen == false) // Check if a player chose the first box in row 1. Location: [0,0]
if(playerTurn)
tft.drawChar(20, 13, TIC, RED, WHITE, 8);
cellStatus[0].playerChose = 1;
tft.drawChar(20, 13, TAC, GREEN, WHITE, 8);
cellStatus[0].playerChose = 2;
cellStatus[0].cellChosen = true;
playerTurn = !playerTurn;
else if(p.x > BOXSIZE && p.x < BOXSIZE*2 && cellStatus[1].cellChosen == false) // Check if a player chose the second box in row 1. Location: [0,1]
if(playerTurn)
tft.drawChar(100, 13, TIC, RED, WHITE, 8);
cellStatus[1].playerChose = 1;
tft.drawChar(100, 13, TAC, GREEN, WHITE, 8);
cellStatus[1].playerChose = 2;
cellStatus[1].cellChosen = true;
else if(p.x > BOXSIZE*2 && p.x < BOXSIZE*3 && cellStatus[2].cellChosen == false) // Location: [0,2]
if(playerTurn)
tft.drawChar(180, 13, TIC, RED, WHITE, 8);
cellStatus[2].playerChose = 1;
tft.drawChar(180, 13, TAC, GREEN, WHITE, 8);
cellStatus[2].playerChose = 2;
cellStatus[2].cellChosen = true;
else if(p.y > BOXSIZE && p.y < BOXSIZE*2) // else if says "if the last if, at the same level, wasnt true, check this.
if(p.x < BOXSIZE && cellStatus[3].cellChosen == false) // Location: [1,0]
if(playerTurn)
tft.drawChar(20, 93, TIC, RED, WHITE, 8);
cellStatus[3].playerChose = 1;
tft.drawChar(20, 93, TAC, GREEN, WHITE, 8);
cellStatus[3].playerChose = 2;
cellStatus[3].cellChosen = true;
else if(p.x > BOXSIZE && p.x < BOXSIZE*2 && cellStatus[4].cellChosen == false) // Location: [1,1]
if(playerTurn)
tft.drawChar(100, 93, TIC, RED, WHITE, 8);
cellStatus[4].playerChose = 1;
tft.drawChar(100, 93, TAC, GREEN, WHITE, 8);
cellStatus[4].playerChose = 2;
cellStatus[4].cellChosen = true;
else if(p.x > BOXSIZE*2 && p.x < BOXSIZE*3 && cellStatus[5].cellChosen == false) // Location: [1,2]
if(playerTurn)
tft.drawChar(180, 93, TIC, RED, WHITE, 8);
cellStatus[5].playerChose = 1;
tft.drawChar(180, 93, TAC, GREEN, WHITE, 8);
cellStatus[5].playerChose = 2;
cellStatus[5].cellChosen = true;
else if(p.y > BOXSIZE*2 && p.y < BOXSIZE*3) // else if says "if the last if, at the same level, wasnt true, check this.
if(p.x < BOXSIZE && cellStatus[6].cellChosen == false) // Location: [2,0]
if(playerTurn)
tft.drawChar(20, 173, TIC, RED, WHITE, 8);
cellStatus[6].playerChose = 1;
tft.drawChar(20, 173, TAC, GREEN, WHITE, 8);
cellStatus[6].playerChose = 2;
cellStatus[6].cellChosen = true;
else if(p.x > BOXSIZE && p.x < BOXSIZE*2 && cellStatus[7].cellChosen == false) // Location: [2,1]
if(playerTurn)
tft.drawChar(100, 173, TIC, RED, WHITE, 8);
cellStatus[7].playerChose = 1;
tft.drawChar(100, 173, TAC, GREEN, WHITE, 8);
cellStatus[7].playerChose = 2;
cellStatus[7].cellChosen = true;
else if(p.x > BOXSIZE*2 && p.x < BOXSIZE*3 && cellStatus[8].cellChosen == false) // Location: [2,2]
if(playerTurn)
tft.drawChar(180, 173, TIC, RED, WHITE, 8);
cellStatus[8].playerChose = 1;
tft.drawChar(180, 173, TAC, GREEN, WHITE, 8);
cellStatus[8].playerChose = 2;
cellStatus[8].cellChosen = true;
// Check to see if the New Game/Restart button was pushed
else if(p.y > 248 && p.y < 314 && p.x > 200 && p.x < 230)
// See newGame() definition below. This function will start a new game.
newGame();
// See the definition below. This function checks if there is a winner, or if the game is over without a winner.
gameStatus();
void gameStatus()
int boardFull = 0;
for( int a = 0; a < 9; a++)
if(cellStatus[a].cellChosen == true)
boardFull+=1;
// These two check if someone won in the top row
if(cellStatus[0].playerChose == 1 && cellStatus[1].playerChose == 1 && cellStatus[2].playerChose == 1)
playerOneWins();
else if(cellStatus[0].playerChose == 2 && cellStatus[1].playerChose == 2 && cellStatus[2].playerChose == 2)
playerTwoWins();
//…removed lots of cases here
else if(boardFull == 9)
noWinner();
void noWinner()
//…removed
newGame();
void playerOneWins()
//…removed
newGame();
void playerTwoWins()
//…removed
newGame();
void newGame()
cellStatus[a].cellChosen = false;
cellStatus[a].playerChose = 0;
playerTurn = true;
blankGrid();
