Hello, I don’t have a lot of programming knowledge but I have already done some personal projects with Arduino and so far it has been going well.
Now I wanted to use an Arduino UNO with Touchscreen to control the operation of a stepper motor that will have to work in a loop, does 160 steps and returns to 0,and so on.
For now I want a button to start the motor loop and another button to stop.
The code I made to try is this:
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 100
#define MAXPRESSURE 1000
#include <AccelStepper.h>
// Define stepper motor connections and motor interface type. Motor interface type must be set to 1 when using a driver:
#define motorInterfaceType 1
#define dirPin 11
#define stepPin 10
const int XP = 8, XM = A2, YP = A3, YM = 9; //ID=0x9341
const int TS_LEFT = 898, TS_RT = 120, TS_TOP = 74, TS_BOT = 903;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn;
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
int cycle ;
void setup(void)
// Set the maximum speed in steps per second:
stepper.setMaxSpeed(1000);
stepper.setCurrentPosition(0);
uint16_t ID = tft.readID();
tft.begin(ID);
tft.setRotation(0); //PORTRAIT
tft.fillScreen(BLACK);
on_btn.initButton(&tft, 60, 200, 100, 40, WHITE, CYAN, BLACK, "ON", 2);
off_btn.initButton(&tft, 180, 200, 100, 40, WHITE, CYAN, BLACK, "OFF", 2);
on_btn.drawButton(false);
off_btn.drawButton(false);
tft.fillRect(40, 80, 160, 80, RED);
void buttons()
bool down = Touch_getXY();
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
if (on_btn.isPressed()) {
cycle = 1;
tft.fillRect(40, 80, 160, 80, GREEN);
if (off_btn.isPressed()) {
cycle = 0;
void motor() {
if (cycle == 1)
// Set the current position to 0:
// Run the motor forward at 160 steps/second until the motor reaches 160 steps :
while (stepper.currentPosition() != 160)
stepper.setSpeed(250);
stepper.runSpeed();
// Run the motor backwards at 160 steps/second until the motor reaches -160 steps :
while (stepper.currentPosition() != -160)
stepper.setSpeed(-250);
stepper.runSpeed();
if (cycle == 0)
motor();
buttons();
Serial.println(cycle);
but my problem is that I can’t stop the motor loop when I want to, I press the off button and it doesn’t respond to the first touch.The start button works fine.
I´m using, a tft VMA412,Arduino Uno,tb6560 driver motor and a nema17.
It´s a program problem?Or something with using d10 and d11 pins from arduino to give the step and direction?
Thank you in advance
