I am using the TFTP Boatloader from the playground
http://arduino.cc/forum/index.php/topic,87455.0.html
i would like to add the watchdog timer mods to this bootloader but i am unsure exactly what needs to be added
i beleive this is the code that needs added again i may be wrong
ch = MCUSR;
MCUSR = 0;
WDTCSR |= _BV(WDCE) | _BV(WDE);
WDTCSR = 0;
here is the main.c i believe it would go in but not sure
/* Name: main.c
* Author: Denis PEROTTO, from work published by Arduino
* Copyright: Arduino
* License: GPL http://www.gnu.org/licenses/gpl-2.0.html
* Project: eboot
* Function: Bootloader core
* Version: 0.2 tftp functional on 328P
#include "main.h"
#include "net.h"
#include "tftp.h"
#include <avr/pgmspace.h>
#include "debug.h"
#include <util/delay.h>
#include <avr/eeprom.h>
uint16_t lastTimer1;
uint16_t tick = 0;
#define TIMEOUT 19 //(5 seconds)
#define VERSION "0.2"
int main(void) __attribute__ ((naked)) __attribute__ ((section (".init9")));
// Function
void (*app_start)(void) = 0x0000;
void updateLed() {
//config of timer1
uint16_t nextTimer1 = TCNT1;
//if timer has started a new cycle increment tick count
if (nextTimer1 < lastTimer1){
tick++;
if(PORTB & _BV(LED_PIN)){
PORTB &= ~_BV(LED_PIN); //turn off LED
else{
PORTB |= _BV(LED_PIN); //_BV(LED_PIN)= byte with LED_PIN set, turns up LED
//Store timer value for next call of updateled
lastTimer1 = nextTimer1;
uint8_t timedOut() {
//Called from TFTP poll
if (pgm_read_word(0x0000) == 0xFFFF){
// Never timeout if there is no code in Flash or if flash is corrupted
return 0;
if (tick > TIMEOUT){
return 1;
return 0;
void ResetTick(){
tick=0;
int main(void) {
debugInit();
_delay_ms(250); //be sure that W5100 has started (ATM starts in 65ms, W5100 150-200ms)
// Set up outputs to communicate with W5100 chip
DDRB = _BV(LED_PIN) | _BV(SCK_PIN) | _BV(MOSI_PIN) | _BV(SS_PIN); //set pins as output
PORTB = _BV(SCK_PIN) | _BV(MISO_PIN) | _BV(MOSI_PIN) | _BV(SS_PIN); //set pins UP
Prescaler=0, ClkIO Period = 62,5ns
TCCR1B values:
0x01 -> ClkIO/1 -> 62,5ns period, 4ms max
0x02 -> ClkIO/8 -> 500ns period, 32ms max
0X03 -> ClkIO/64 -> 4us period, 256ms max
0x04 -> ClkIO/256 -> 16us period, 1024ms max
0x05 -> ClkIO/1024 -> 64us period, 4096ms max
TCCR1B = 0x03;
SPSR = (1<<SPI2X); //Set SPI Clock to max
trace("\r\nTFTP Bootloader for Arduino Ethernet, Version ");
trace(VERSION);
// Initialise W5100 chip
trace("\r\nNet init...\r\n");
netInit();
trace("Net init done\r\n");
trace("TFTP Init...\r\n");
//Open TFTP Socket 3 (Default UDP 69)
tftpInit();
trace("TFTP Init done\r\n");
for(;;) {
if (tftpPoll()==0) break;
updateLed();
trace("Start user app\r\n");
// Exit to foreground application
app_start();
return 0; /* never reached */
