The Arduino does not execute commands when I unplug the Arduino.. It only executes commands when I press the restart button
Look at the board from the top there it says a switch in this place I connected a switch and disconnected and connected the Arduino.. the switch is only connected to the ground line is this a problem or what should I cut off the positive and negative lines
Thank you very much for the help
